Diesel Warm-Up -- How Long -- Why?
   / Diesel Warm-Up -- How Long -- Why? #91
:confused:How in the heck does that work?:confused2: Diesel should just rev up with more fuel since its full air allthetime.
larry
It doesn't increase the fuel, it increases the fuel/air ratio.
There is a valve on the exhaust that closes down when the engine is cold and gradually opens as the temperature increases. (I'd presume there is a controller that would open the valve if there was a sudden increase in demand for power.) It's kinda' counter intuitive. It throttles the air to increase fuel air ratio during warmup. I understand some people wire them up and use them for exhaust brakes. (See Powerstroke website)
   / Diesel Warm-Up -- How Long -- Why? #92
I thought it was the other way around ?
Nope, more fuel/air ratio, more temperature. You don't necessarilly have to add more fuel, you can reduce the air flow at constant fuel flow and have the same temperature effect.
   / Diesel Warm-Up -- How Long -- Why? #93
That would work. Some Dodge/Cummins owners use the exaust brake to load/heat up their motors. Espar makes a diesel fueled coolant heater that can be used for warming up a cold cab or adding heat to the system... I thought about installing one whilst I was still working for a living, but just retired instead.... :) Some of the Dodge/Cummins can have their 3 cylinder idle enabled which fuels only three of the 6 jugs.... makes quite a racket I have heard. I have never enabled mine.
Espar Heater Systems | A World of Comfort | FAQ's
..and a link to 3 cyl idle if you are interested..
2001 Dodge Cummins Diesel Cold Start 3 Cylinder Idle - YouTube
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
Caterpillar 2PD5000 5,000LB Diesel Warehouse Forklift (A53421)
Caterpillar...
ASSET DESCRIPTIONS & CONDITION (A54313)
ASSET DESCRIPTIONS...
2019 Doosan LCV6W Towable LED Light Tower (A54811)
2019 Doosan LCV6W...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
