orezok said:I've been pondering this and though I'm no expert, there seems that there would be a difference between gas and diesel engines. All engines lose power at altitude, but I think diesels would lose less. Gas engines have to run a a very narrow fuel to air ratio (about 15:1). Diesels, because they run unrestricted have a very wide ratio from 100:1 at idle to ??:1 at full power. Given this information, it would seem that the diesel would maintain it's full power up to a higher altitude when the amount of air falls below it minimum F/A ratio.
Hmmm...
I think you are right.
Are you talking about a diesel? If so, that is not the way a diesel works.Yep. I have less power (about 6-8% at 8500 ft MSL) than you folks down by the big ponds, but I use less fuel/hr at a given RPM than you do, since fuel is mixed as a ratio to O2!!!
Fuel makes power...the engine is just a mechanical contraption to accomplish the conversion of chemical energy in the fuel to mechanical energy. On a gas engine, the amount of fuel going into the engine diminishes as altitude increases because there is less O2 for the fuel to combine with and the fuel/air ratio is limited to a very narrow range, compared to a diesel. The diesel starts out with a surplus of air and the amount of fuel going into the engine is not reduced...so why would the power be reduced?
