Difference between chizle plow and 5 bottom?
/ Difference between chizle plow and 5 bottom? #1
65commander
Wellington ohio
1965 ford commander 6000 diesel, john deere 60, john deere 40
Im new at this and my buddy im getting into farmin with know it all but i dont, its killing me not knowing right now but i can buy a 5 bottom plow with 12's or a chizle plow, all i really know is its faster but also i have a 1965 ford commander diesel that can for sure pull a 5 bottom on 12's but what size chizle?
/ Difference between chizle plow and 5 bottom? #2
Looks like your Ford is somewhere between the JD 3010 and the 3020 in horsepower. Depending upon the size of the sweeps and if your tires are filled and if the ground ain't all clay gumbo.. I'd guess you'd be lookin' at a 10' - 12' chisel plow.
They pull hard if they're put into the ground too deep on the first pass! Kinda like a breaking disc or disc plow. By the 3rd pass; you should be able to shift up a couple of gears! :)
AKfish
/ Difference between chizle plow and 5 bottom? #3
I've not seen a 12" cut on a five bottom plow in years! Most common is 16,18 or more. I'd keep it light behind a 6000 ford! Find a four bottom or on the chisel plow side find a seven shank three point.
/ Difference between chizle plow and 5 bottom? #4
Agree on the 7 shank chisel. We used to pull a 9 shank with a 4020 it was all that tractor wanted.
/ Difference between chizle plow and 5 bottom? #5
I don't recall exactly; but, the shanks were probably around 18" apart. So, a 9 shank chisel would be about 14' overall width, yes? Also, the sweeps (or plow points) made a huge difference in how hard the chisel pulled! Big sweeps - darn hard pullin' - even a 7 shank model.
Pretty straight chisel point - not a hard pull really - but, it didn't turn over the ground much either.
AKfish
/ Difference between chizle plow and 5 bottom? #6
9 shank chisel, 1 ft spacing. 9 ft wide with 4 inch wide twisted shovel points, called mini-moldboards. Hard to pull but buried almost all the residue.
/ Difference between chizle plow and 5 bottom? #8
I agree with others who recommended a 7 shank.
/ Difference between chizle plow and 5 bottom? #9
My only comment to this is the fact that if the 5 bottom you are referring to is a moldboard, the two implements that you mentioned do entirely different jobs.
/ Difference between chizle plow and 5 bottom? #10
as said the 5 bottom plow an chisel plow are differant.the 5 bottom plow is used to breakup ground that hasnt been plowed in years.the chisel plow is used behind the plow to bust up the ground deep an bust the hardpan.now for the tractor,a commander has about 70hp.i wouldnt hold my breath on it pulling the plow or chisel deep in the ground.but it might pull it.but you really need 100hp tractor to pull emm with ease.
2014 GENIE S-40 TELESCOPIC BOOM LIFT (A64279)
2014 GENIE S-40...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A61569)
2009 Mariah SC23...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 KENWORTH T680...
2005 BOBCAT 323J EXCAVATOR (A64279)
2005 BOBCAT 323J...
