Difference between the Branson 2515H and the 2515R?
   / Difference between the Branson 2515H and the 2515R? #1
Audiobeer
2515h
What is the difference?
   / Difference between the Branson 2515H and the 2515R? #2
One is Hydrostatic drive and one Gear driven . Other than that I believe the stats are the same on the loader and three point .
   / Difference between the Branson 2515H and the 2515R? #3
I own the 2515H . Ask any questions you would like and I will do my best to answer.
I was getting ready to close the deal on the 2515H with the front loader and fork lift and filled tires for $20k. Hoping that’s fair.
   / Difference between the Branson 2515H and the 2515R? #5
Just for comparison, my dealer (NE of DFW) has the following deal listed for that tractor. It is a package deal.
   / Difference between the Branson 2515H and the 2515R? #6
The prices on TractorHouse vary wildly by region, but that price would be excellent here in Maine.
   / Difference between the Branson 2515H and the 2515R? #7
TYM t474 HST with loader was selling for $25,900 in Middle Tennessee last month. The extra $5,900 buys 48hp.
Thank you so much. I will for sure!
   / Difference between the Branson 2515H and the 2515R? #9
There is a big practical difference between 25hp and 48hp when it comes to operating something like a rotary cutter. IMO, a 25hp tractor would run about a 5' cutter where 48hp can easily run a 6' cutter with power to spare. The T474 also has dual hydraulic pumps and is a heavier tractor.
   / Difference between the Branson 2515H and the 2515R? #10
I just spent 5 hours mowing today with my new to me Kubota MX5200 52hp tractor after trading in a 35 hp Mahindra 3525. My experience with a 6' cutter cutting fairly thick vegetation is that the 35hp tractor struggled in places with the 6' cutter. The 52hp machine using the same 6' cutter doesn't struggle.
In fact, I have a hillside area that I haven't touched in probably 10 years that is overgrown with briars and honey suckle taller than the ROPs on the MX. The MX in 4wd backed right over it and cut it without slowing down or stalling going uphill in reverse. I was operating around 2100 rpm, so I wasn't using all of the available HP, either. In my personal experience, there's a very substantial difference in speed and ease of operation going from 35 hp to 52.
I wouldn't even have tried this with my L2501 (25hp).
If you are considering the 2515, I very much believe you should consider the T474, even if it means working extra hours to pay for it, because the extra HP will give you a machine that is capable of doing much more and doing it faster where 25hp would choke trying to do the same work.
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2008 DOOSAN G25 GENERATOR (A53843)
2008 DOOSAN G25...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
2013 DODGE CHARGER SEDAN (A56129)
2013 DODGE CHARGER...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
SEET BOX W/ CABLE SLINGS (A54757)
SEET BOX W/ CABLE...
