Difference in price in zero turn mowers in Lowes and those on the JD website?
   / Difference in price in zero turn mowers in Lowes and those on the JD website? #1
andrewj
Platinum Member
South Carolina
JD 5105
Just cruised through lowes and saw zero turns for around 2,500. But when you go the configurator you are suddenly looking at the 12,000 range! How can a zero turn have ten thousand dollars difference? And don't tell me deck thickness!!!!
   / Difference in price in zero turn mowers in Lowes and those on the JD website? #2
Just to get started the hydro's used. Some I put at about 1,000 hours life and some I put at 10,000 hours. Engines and the frames and a whole lot more! Welded decks vs the stamped steel, It's more money for a comparable stamped deck the welded. If you don't have sandy soils you might find the stamped deck to work better.
   / Difference in price in zero turn mowers in Lowes and those on the JD website? #3
Different series of mowers. Lowes has the lower-end Z2 and 400 series. You're seeing the Z900's which are the bigger commerecial mowers.
There is also a Z700 series, mid range.
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A55788)
2007 Ford F-150...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
Giyi  Hay Spear (A53316)
Giyi Hay Spear...
2002 VOLVO L150E WHEEL LOADER (A51246)
2002 VOLVO L150E...
Case 721C Wheel Loader (RIDE AND DRIVE) (A50775)
Case 721C Wheel...
2005 Ford F450 Landscape Dump (A47477)
2005 Ford F450...
