Different Hydraulic oils and such
   / Different Hydraulic oils and such #11
Tractor fluid is hydraulic fluid with additives to make wet clutches and brakes work properly. If you didn't add all that much hydraulic fluid, like a few quarts, it's probably fine. All you've done is diluted the additives a little. If you added gallons, I'd change the fluid.
   / Different Hydraulic oils and such #12
Yeah ^^ it's the additives package that makes the difference. I know CAT switched my mini-ex to TO-4 from TO-2 because the additives in TO-2 were eating the metals in the trans and hydros & causing failures. Best to go with the specs recommended by the OEM.
Sorry for the delay, was not able to get on this site the last couple of days. Thanks to all of the replies and suggestions. I have decided to take it in to the dealer and let him do a 300 hr service (it has 272 hrs on it) that way it can be done right and I just have not got the time to do the service myself.
New Holland LB75B (A57148)
New Holland LB75B...
2004 Mack CV713 Granite Fuel and Lube Truck (A56858)
2004 Mack CV713...
2019 International DuraStar 4300 24ft. Box Truck (A56858)
2019 International...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
