Differential lock won't disengage
   / Differential lock won't disengage #1
r40kh
Nova Scotia
Kubota M7040
Was plowing a steep driveway after a major snowfall overnight. Tractor wouldn't climb the driveway so I engaged the differential lock and very nicely climbed the steep hill. It now appears the differential lock won't disengage as both rear wheels are spinning at the same time. Foot lever is out all the way and the linkage appears to be working. Any suggestions on getting this disengaged. Also this would have been the first time the lock was engaged as the tractor only has just over 100 hours
Tried that..I've plowed about a dozen driveways now with lots of reversing and still no go
   / Differential lock won't disengage #5
Turn the wheel all the way to one side and hit the gas .
   / Differential lock won't disengage #6
If Murph's solution doesn't work, then try shifting out of 4WD into 2WD and then do what Murph suggested, again.
Result may be very jerky/hard to control, so I'd use low revs and some feather on the clutch first time you try it.
Well I got it to disengage...talked to the dealer and they suggested that the problem was probably related to it not being used. I got underneath and lubricated all the pivot points and after several attempts it did come out. I notice the foot lever is still not returning on its own so I suspect it will take some time for the spray lube to work its way through. I have never had any occasion since I bought the tractor to need the diff lock...but I guess from here on in I will engage it every now and then and I'll be sure to keep the linkage well greased. Lesson learned! Thanks guys for the replies
   / Differential lock won't disengage #8
Good job.
   / Differential lock won't disengage #9
Thanks so much for coming back with the fix!
I'll have to check the linkage lube on mine.
I don't use it very often, but when I do I really need it.
   / Differential lock won't disengage #10
"Thanks guys for the replies" r40kh (prob solved)
great example of how well this forum works
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
GRADALL XL4100 IV MOBILE EXCAVATOR (A51406)
GRADALL XL4100 IV...
2007 JOHN DEERE 7630 TRACTOR (A53843)
2007 JOHN DEERE...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2011 Nissan Rogue SUV (A53424)
2011 Nissan Rogue...
