digging up rutted, pothole filled gravel road bed
   / digging up rutted, pothole filled gravel road bed #11
"" You never want to re grade or break up an existing gravel road if you can avoid it. This is the worse thing you can do because you loose material every time you do this and once it's compacted again, it will be thinner then before you started. The only time you would do this is if you are going to add enough additional rock to the entire road to build it up thicker. This should only be done when the entire road is failing and the rock is less then four inches thick. Then you need to add enough rock to the entire road to make sure you are 4 inches or thicker. ""
Ripping/scarifiing a pot holed road is a very acceptable and common practice. It does require a grader and vibratory/tired packer to do it properly?
Working pothole by pothole lets you do it all over every year and usually lasts till the first rain.
   / digging up rutted, pothole filled gravel road bed #12
I have a mile long gravel drive that has only been graded over all these years. It is now 32 years old. I have two spots that present problems and its because I have trouble getting water to drain from these spots. But I keep working on it and now the spots a quite small. Three years ago I got a grading scraper and this implement made maintenance much easier. I used the scarifiers the first time thru the two spots and then graded it all smooth. I carefully waited and the first rain I was out there rolling the two spots.
If your drive is long and you are going to redo it all - break it into chunks. My driveway naturally breaks into four sections. What I learned on the first section will certainly be used on the next three and so on. A long driveway is a continuous project.
   / digging up rutted, pothole filled gravel road bed #14
Pics of the grading scraper? Your gravel road sounds a lot like mine: 85% is no big deal, the rest is potholes and mudholes.
Thanks,
CONCRETE POWER TROWEL (A55787)
CONCRETE POWER...
2005 Military Trailer (A55758)
2005 Military...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
2007 JLG SKYTRACK 6036 TELESCOPIC FORKLIFT (A52705)
2007 JLG SKYTRACK...
UNUSED DIGGIT 20'X30' METAL GARAGE CARPORT SHED (A54757)
UNUSED DIGGIT...
