Dirt scoop in action (pictures)
   / Dirt scoop in action (pictures) #1
cchoate
Near Buffalo, NY
Kubota GL3430 HST
Just some pics of actual dirt dug using a scoop. One trick I found quite by accident :
Tilt the scoop to the ground and back up a little. The scoop will catch and the tractors back tires will come off the ground.
Results : The scoop will tilt almost vertical and will dump easier.
Here's another.
One more. This is with about 3 "digs" of pond dirt. VERY heavy!
   / Dirt scoop in action (pictures) #4
Very Interesting. My dealer has been putting me off of getting one of these. They look like a good idea to me, but he says that a FEL does everything a scoop can do and does it better. I am not so sure. Now that you have used it a bit, what do you think?
   / Dirt scoop in action (pictures) #5
Another question is How big is that scoop?
   / Dirt scoop in action (pictures) #7
<font color=blue>What are the rear set of pins for?? <font color=black>
Don't you Aussies have dirt scoop tugs of war with your machines? That's how we resolve the "R1 vs R4" and "Gear vs Hydro" wars!
Seriously, they are used when the scoop is pulled forward in lieu of being pushed in reverse. They are bi-directional but that's socially acceptable here................chim
   / Dirt scoop in action (pictures) #8
You mean "Don't ask, don't tell?"
   / Dirt scoop in action (pictures) #9
Nuru, those scoops come in two sizes. Thirty inch wide and 24 inch wide. The thirty inch is the most common. I special ordered a 24 inch at TSC to use with my John Deere 650.
   / Dirt scoop in action (pictures) #10
Hawkflyer
Let's see.....dealer thinks you should buy a $5,000 FEL instead of a $250.00 pond scoop. I think he has your best interests and ONLY YOUR best interests in mind. /w3tcompact/icons/smile.gif
2012 JOHN DEERE 410K BACKHOE (A51406)
2012 JOHN DEERE...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2017 JACTO ARBUS-1500 DIAM LOT NUMBER 66 (A53084)
2017 JACTO...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
LEEBOY PF1510B ASPHAULT PAVER (A51406)
LEEBOY PF1510B...
