dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,611
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
I'm an inboard guy, piston applies pad directly to disc with more force. Outboard pad is just pulled in from the outside. Granted the inboard pad is retracted from the disc when the piston moves back in and although the outboard pad spends more/most of its time in contact with the disc, it is "just along for the ride".
That's what they call a floating caliper. The other kind is a fixed caliper, where pressurized hydraulic cyls are on both
sides and the caliper is firmly attached to the hub. In a floating caliper, there are one or 2 cyls only on one side (usually
inboard?) of the caliper. So the whole caliper moves when you press the brake pedal. When you release, the drag
on the guide pins or rails keeps one pad touching the disc, while the other one backs off a little as the cyl retracts.
That said, I don't notice much of a difference on any of my vehicles, but I have no automatics, and pads are
rarely changed. I also no longer live in a cold climate where salted roads cause havoc to floating calipers. If
you have an automatic PU with floating calipers, I would expect you to have more pad wear on the side that
has the passive pad (no cyl). Automatic tranny-equipped vehicles use the brakes a lot more than manuals.
I notice that Arctic Cat quietly changed over to fixed from floating calipers within their utility ATV line.
