Disc or drum mower to buy??
   / Disc or drum mower to buy?? #1
Carl1
Dayton,Ohio
IH 574 and IH424,Ih3414 loader
Looking to replace my 1209 moco. Is a disc better then a drum mower?
my tractor is only a 52 hp IH. any advice would be apprecated.
   / Disc or drum mower to buy?? #2
Either will work. Try a demo before you buy there are advantages to both. I had a CIH disc mower that was shaft drive. It seemed easier to pull as far as horse power. I dont rtemember the number but it had 6 blade holders. Probably 7 ft 9 inches or so.
   / Disc or drum mower to buy?? #3
Our new disc mowers by First Choice are $4995 for the 6 disc (8ft). 5 1/2 ft drum mowers are ok, just a little less on the acres per hour that can be cut in addition to being heavy in the transport position (fully extended to the rear of the tractor)--Ken Sweet
Email sweet@scrtc.com
Phone 270-528-3323-mon-fri-8-5-cst
   / Disc or drum mower to buy?? #4
Like Sweet I'll recommend the Fort First Choice models. Choose your size. I have run one for going on 4 years now with the only problem being a driveshaft yoke. That was my fault. I hit a guywire and overextended the mower, before I could shut it down it had wallowed out the yoke. I have cut about 1000 4x4 rolls and 3000 squares with it. Of all the equipment I have bought it would rank at or near the top in both reliability and value.
   / Disc or drum mower to buy?? #5
I bout the 8' Fort Disc Mower from Ken a few years back and have had absolutley no trouble with it at all. Really makes cutting hay go very smoothly and leaves a nice looking field in the end that seems to green up pretty quick.
   / Disc or drum mower to buy?? #6
If you are looking to get a conditionor too you are very limited with 52 hp. I only know of a couple of machines, a NH 408 or the narrowest shaft drive agco models and even then if you are in hills its a no go.
2018 GENIE GTH636 TELESCOPIC FORKLIFT (A51246)
2018 GENIE GTH636...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
2517 (A51248)
2517 (A51248)
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
Kioti DK 35, 4WD, Quick Attach Loader with Bucket  (A52384)
Kioti DK 35, 4WD...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
