Disc Purchase Question
/ Disc Purchase Question #1
Riddler
Sonoma County, CA
New Holland TN75VA, New Holland TC45DA, New Holland TC18
I need a 4' wide three point disc attachment to work between some vine rows. I'd love to find a reasonably priced used one, but I have never found a decent source for used equipment in Northern California. Does anyone know of a source I should check?
Also, I was allowed to demo a new one recently, and while it was well built and worked great, it seemed rather pricey to me at over $4,500. I can't remember the brand. Is that the going price for a unit that does the job reasonably well? Can anyone recommend a less expensive make and model?
/ Disc Purchase Question #2
i know things are expensive in CA but didn't know they were *that* expensive. ;-) are you looking for a disc harrow? like this:
BB, thanks for responding.
I am just learning about discs, so I am not sure what the differences are between offset discs, tandem discs, disc harrows and the like, but your picture looks similar to the unit I tested out recently.
It may very well be that the unit I tested is overkill for my purposes. At $4,500, I can't help but ask that question.
All I am trying to accomplish really is regular weed suppression in a 4' strip between the vine rows and, occasionally, seed bed preparation for reseeding a cover crop. I don't have a need for deeper tillage, or to turn the soil over to mix amendments or surface vegetation to a great degree.
Right now, I have about 80 rows to deal with, each about 450' long. In the next few years, though, that number will double. The soil will likely have plenty of moisture in it when I am performing the weed suppression or seed bed preparation.
Since I posted my original message, I checked into the compact disc (Model 14-10) and flip over disc (Model 16-8) that King Kutter makes, both of which can be pulled by a compact tractor or ATV. The compact disc as two rows of notched discs, but cuts only 33" wide. The flip over disc cuts 48" wide, but has only a single row of notched discs. Will these models work well for my limited purposes? I am glad to make multiple passes over each row to get the job done, especially if it means I can dispense with using something as powerful and pricey as a NH TK75VA crawler.
Hope you have some thoughts on the subject.
/ Disc Purchase Question #4
You can get a new 5-ft wide 3pt disc at Tractor Supply Co. for $600.
Northern Tool has a 4-ft Howse 3pt disc for $400.
I assume that you are doing light tilling between in your vineyard so a tandem disc harrow is what you want. Your tractor is more than enough to handle a small 4-ft disc.
/ Disc Purchase Question #5
i think a disc harrow (tandem disc) or cultivator would be fine for what you need. a 4ft disc harrow should run $400-$500. there might be other options for you that others may offer but i think either of these would work fine for what you describe.
/ Disc Purchase Question #6
Holy cow! $4,500!!! What did your friend let you use? A John Deere 637 35 foot flex harrow?!?!?
/ Disc Purchase Question #7
I think the person who talked to you added in another zero to the figure or thought you were a complete idiot.
Anyways, I think you would be much happier with a PTO driven tiller for weed suppression and seeding. You can just set the depth control an inch or so deep to avoid root damage to the vines.
One pass is all it would take vs 3-4 passes with a disc, and any weed would get chopped into little tiny pieces wheras with a disc there will be some escapees.
Plus, the time you save will pay for the tiller vs. the disc over the long run.
/ Disc Purchase Question #10
Dude! Those Erb & Roberts Harrows you listed there in that link are super-duper heavy duty. I've never seen anything like that. Couple thousand pounds for some six footers! That's what I want. Unfortunately my tractor wouldn't be able to lift it. Looks they're mostly used in forestry for fireline maintenance and cutting.
/ Disc Purchase Question #13
Glowplug said:
Yeah, no kidding! They're already "too heavy" for my tractor. But I want one!
Ah come on now, as we all know, any 50 hp tractor will pull those.:rolleyes: As I have said over and over, all disks are not created equal and those are a great example of some disks that are not all that wide and you have to have some serious weight and power to pull them.
After looking at those heavy duty disks, does anybody still wonder why their 1400lb set only digs in a couple of inches? You get what you pay for and if you want a good set of disks that work when you go to use them, it's going to cost some $$$$. Of course you need a capable tractor to go along with those heavy duty disks.;)
Thanks for all of the great feedback. For those still wondering, there was no mistake about the $4,500 pice tag on the 4' tandem disc that I took for a test spin. It looked and weighed in the range of the units that Gizmo references in his posts. The unit weighed over 2,000 pds, I'm sure. I believe it had 20" or larger discs, all sort of adjustments and an unlimited life span. A superb unit but overkill for me.
Dixie, I am giving alot of thought to your suggestion about using a tiller for weed suppression between the vine rows. As it turns out, I have the opportunity to purchase a small (18HP) used (100 hours) CUT (NH TC18) with a 4' brush hog and 3' tiller for $8K. When I saw that the tiller came with the deal, I thought about setting the thing for a shallow cut and knocking down the emerging grass/weeds that way. It is also possible to offset the tiller, so I can get closer to the vine rows. If I buy the thing, I'll will experiment with the tiller before I consider investing in a disc harrow. I need the tractor and mower anyway (my NH TC45DA and 6' rotary cutter are too wide for vine rows), so getting the tiller also makes the deal too timely to pass up.
/ Disc Purchase Question #15
I would think that those heavy multi-thousand pound disks serve almost as plows. For most of us, that is not what we need or want a disk for. We use them as harrows, not plows.
And the ironic thing is that I don't think a 2000 pound 6' disk is going to be anymore effective on unprepped soil in my area than an 800 pound 6' disk. In fact, I know this for sure. Watched a 2000 pound Tufline with 22 inch notched disks skid along like it was on concrete. It worked great after the field was plowed.....with a plow.
And if you have a plow, you probably don't need a super heavy, super expenisive, hard to transport, hard to pull disk.
Regardless, I don't think the OP needs a $4500 disk and that for his purposes a $600 one would probably function just fine. And as mentioned, a tiller would probably be even better.
/ Disc Purchase Question #16
Every tool has its intended purpose, sometimes we stretch their use into many purposes, but that doesn't change what their intended use is.
/ Disc Purchase Question #17
N80 I have a 7200 pound Taylor-way disc harrow that will plow up a paved road if you want to. And you don't have to use a plow first.
/ Disc Purchase Question #18
That's exactly what I would expect a 3 1/2 ton disk to do. What's your point?
/ Disc Purchase Question #19
I'm not tryin' to be a smart A--, but if your doin' grape vines check with a expert to see what they use. A friend told me grapes are fussy about their roots. I mean don't destroy your vineyard by not using good tilling. bjr
Good suggestion BJR. As it turns out, I have a good deal of expert support for the vineyard operation.
Between the rows of a new planting, the goal is simply to knock down emerging annuals a few times a year. The ground is relatively soft and usually has some (or alot) of moisture in it, so it doesn't take much to do the job. A light duty disc, a tiller at a very shallow setting, or even drag harrow works fine. No need to get anywhere close to the vine roots.
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
2001 INTERNATIONAL 4700 4X2 S/A UTILITY BODY TRUCK (A66091)
2001 INTERNATIONAL...
2022 YANMAR VIO80-1A EXCAVATOR (A63276)
2022 YANMAR...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
Spirit scooter (A64557)
Spirit scooter...
2020 Freightliner M2 106 Johnston VT652 Sweeper Truck (A64556)
2020 Freightliner...
