Discs- Round or Scalloped?
   / Discs- Round or Scalloped? #1
dougg
Bronze Member
Do scalloped discs work any better than round ones?
   / Discs- Round or Scalloped? #2
In trashy ground, yes. The vegetation is turned and cut better with scallops.
   / Discs- Round or Scalloped? #3
My experience has been that they cut up sticks and other surface material better. They seem to work in hard ground better.
Serrated disks are my preferred disk, others will vary. ;)
   / Discs- Round or Scalloped? #4
Scallops are king. Trash, hard ground, sod, sticks. They eat it all faster/better and like it.... compared to the "smoothies"
   / Discs- Round or Scalloped? #5
On lighter disc harrows, which tend to have thinner discs, the scalloped/notched type are somewhat prone to bending at the notch if a hard rock is impacted.
So your soil rock content should be considered.
In my part of Florida, where the few rocks we have are soft lime rock, I pull notched discs on both front and rear gangs.
   / Discs- Round or Scalloped? #6
As jeff9366 stated, rocks are problematical. I've had to replace several blades because of bending. A couple of them had some of the scallops break completely off.
Just mechanically, it would seem that the solid blades would last longer than the scalloped. They all wear however.
The scallops do penetrate the ground better because the weight of the disc blade is concentrated on a "point" rather than spread over a larger contact area.
Those in the know have recommended scallops in the front gang(s) and smooth in the rear(s).
Thank y'all!
   / Discs- Round or Scalloped? #8
The scollopsed discs will be round all too soon, anyway. :(
   / Discs- Round or Scalloped? #9
Sometimes we all run across a no brainer heck of a deal and buy what we run into , but I like "Scalloped" disc . Even on my plow coulter wheels.
Boone
2025 Wolverine TR-26-02C Class 2 Quick Hitch (A47484)
2025 Wolverine...
2025 Wolverine BC-13-72W UNUSED 72in Brush Cutter (A47484)
2025 Wolverine...
2025 Wolverine...
2014 Ford Taurus Sedan (A44572)
2014 Ford Taurus...
2025 Wolverine GB-11-72W Grapple Bucket Attachment (A47484)
2025 Wolverine...
Kubota ZG227 Zero Turn Mower (A47484)
Kubota ZG227 Zero...
