Disengage parking brake motor dies
   / Disengage parking brake motor dies #1
jman1717
This is on the z-force 44. When I start the mower and take the parking brake out of the on position the motor dies. I have looked this over and can't put my finger on it. Just thought I would see if anybody else has had this problem. Thanks. I also made a stripping kit for it, if anybody is interested. /forums/images/graemlins/confused.gif
   / Disengage parking brake motor dies #3
First guess would be the seat switch is bad. Jumper wire the seat switch and try again. If this doesn't work post back and I'll see if I can cause this anyother way on mine.
   / Disengage parking brake motor dies #4
   / Disengage parking brake motor dies #5
Does parking brake need to be engaged on startup? If so, check switch on parking brake.
   / Disengage parking brake motor dies #6
Yep. The brake has to be on to start the mower and has to be off before you can close the steering levers to go. But I can move the steering levers with the brake on and it still tries to shut off like it should. Is there away to bypass this for today so i can mow. Son has 1st birthday tomorrow and the wife will die if the grass is not mowed. Thanks for the replies I'll try the jumper for the seat switch.
   / Disengage parking brake motor dies #9
I just looked at the switch in the parts book and it says the switch is normally closed so instead of a jumper you may just have to unplug it. I'll go out now and check it out and let you know shortly.
   / Disengage parking brake motor dies #10
AT 26" x 11-12" (A52377)
AT 26" x 11-12"...
2019 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4X4 - 72258 miles -Altec AT40G Boom (A53472)
2019 Ford F550...
2021 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2021 Ford F-250 XL...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
A1 MIST SPRAYERS RESOURCES, IN TERMINATOR 60 R LOT NUMBER 42 (A53084)
A1 MIST SPRAYERS...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
