DIY Mechanic Mistakes
   / DIY Mechanic Mistakes #51
Years ago I was building a project and we hired one of our workers sons for a summer job as a gofor. The kid was about 16 and it was his first job.
One of the carpenters sent him to get a couple of 2x6's for blocking. After about 10 minutes he returned and told the carpenter that he couldn't find any 2x6's, all he could find were ones that were 1 1/2 by 5 1/2 :laughing:
   / DIY Mechanic Mistakes #52
New clerk in hardware store ask if he can help me find something. I need a one inch bolt. He says they don't have any that large, but could I use two half inch bolts instead.
Bruce
   / DIY Mechanic Mistakes #53
Bruce
A hardware didn't have that size?? Maybe he didn't graduate high school or he failed common sense class
   / DIY Mechanic Mistakes #54
I always replace my brakes myself, and I have always had Chevys. I have 2 C Clamps I use to retract the brake piston in the caliper so the new pads will fit. I was helping my dad change the brakes on his Ford Fusion, and my C Clamps were not big enough, so we bought a large clamp to do his brakes. I was cranking the clamp closed, and his piston was not budging. I figured it must be stuck, so I kept turning. Pretty soon I realize the clamp is bowing. We go online, and the Ford pistols are threaded, and you spin them to retract them. DIY Rule - never assume!
   / DIY Mechanic Mistakes #55
Was it s rear disc caliper? Maybe it was the parking (emergency/cable/manual) brake mechanism.
   / DIY Mechanic Mistakes #56
broke off a bolt on a starter once, on an F150. drilled a hole in the end, then broke the "easy out" in the hole. Used a C clamp to hold on the starter, and took it to a shop and they fixed it. I didn't ask how.
   / DIY Mechanic Mistakes #57
They sell a special tool to twist the piston to retract it. I used my special tool called needle nose pliers to lock into the two little holes and spin the piston. I think it has to do with the electric emergency brake system the Fusion has.
   / DIY Mechanic Mistakes #58
Just last week I was re assembling a dirt bike engine replaced some transmission gears, all bearings new top end, had it about 90% complete just the clutch side to assemble, and to my horror I realize the only way to install the clutch pushrod is to split the cases and start over😂
   / DIY Mechanic Mistakes #59
Not sure which Fords have the "Twist" calipers that must be turned in, but have heard about them for a while.
M
   / DIY Mechanic Mistakes #60
Not sure which Fords have the "Twist" calipers that must be turned in, but have heard about them for a while. M
Any disc brake that has a cable parking brake must be turned to re-set the auto adjuster for the parking brake.
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A54757)
UNUSED WOLVERINE...
2016 Dodge Journey SUV (A53424)
2016 Dodge Journey...
2003 Broce Broom RJ350 Ride-On Sweeper (A52377)
2003 Broce Broom...
2014 10ft T/A Dump Trailer (A51691)
2014 10ft T/A Dump...
RING 3 STARTS HERE @ 9:30 AM (A54757)
RING 3 STARTS HERE...
16FT box truck (A53422)
16FT box truck...
