DIY steel flagpole for July 4
   / DIY steel flagpole for July 4 #11
Great idea . I was thinking of doing the same thing and am glad to find this tio save on making a design of my own. That provision fo rotatingbitvdown for repairs is slick and simple..
My only question is why the 10 wire? I'd just ,use a 14 buried in plastic tubing or 12 if I was going to put an outlet out there which is a nice touch.
   / DIY steel flagpole for July 4 #12
He didn't run 120v out there. If I was going to do that, I would use 12-2 UF and skip the PVC.
With low DC voltage, you need upgraded wire size to combat voltage drop on longer runs, much more so than with 120v AC. It boils down to the amp flow being higher in 12v than 120v for the same wattage.
Nick
   / DIY steel flagpole for July 4 #14
Very nice. Love how you designed it to tilt so you could have access to the entire pole without using a ladder!!!
   / DIY steel flagpole for July 4 #16
^^^ :confused:
Great job...lot's of 'Merican ingenuity there.
   / DIY steel flagpole for July 4 #17
I must say...WOW, you built that to last, in fact I suspect that flagpole will be standing tall long after your your grandkids are gone. Make sure you inscribe on the pole, you name and date, you just created a piece of history...
OK - one more ...
I wanted a more finished look for the base tube tops. I took a chance on some 1 7/8" fence post caps whose description was an actual measurement of 2". They fit over a 1 7/8" metal fence post & Lowes had them for $0.95 each - but only as a special order & they took a while to show up. This is the critter:
After checking fit against the 2" tube end, I made a half dozen hacksaw cuts around the base to allow the skirt to deform inward more easily, then tapped them into the tube tops with a wood block & hammer.
Pretty much the finishing touch for the hardware.
Nick
   / DIY steel flagpole for July 4 #19
Looks great Nick :thumbsup:
Rgds, D.
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2239 (A51244)
2239 (A51244)
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
2021 Ram 1500 Bighorn (A53472)
2021 Ram 1500...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
