Traction diy tire antifreeze
   / diy tire antifreeze #1
tjkubota93
Veteran Member
Arlington, TN
Kubota bx1860
I saw on the internet where a lady makes her own windshield washer fluid with 1 gallon water, 8oz isopropyl alcohol, and 1oz castille soap. Yall think I could load my tires with a 1 gallon water/8 oz isopropyl solution? That would cost about $0.88 per gallon. I dont need soap or blue color for Inside tires (unless soap would help the rubber). I am a tight waud so I like stuff like that. I also thought about using rv antifreeze. Any thoughts?
   / diy tire antifreeze #3
From the inside of a tire...... All tractors look the same.....
I loaded my rear (turfs) with regular auto anti freeze and low temp windshield washer fluid....
Each tire held 22 gallons. I used 5 gallon anti freeze and 17 gallon ww fluid.
But I live in a lot colder zone than you. (northern zone 3)
I have read of people using rv anti freeze. I have no idea at what concentration. The thinking if it is lost on the ground it is less toxic than auto products or salt.
If you use the mix you describe, I would think you would want a little soap in each wheel to give the rubber and steel (if tubeless) a little coating of lube.
Good luck
Thanks. I got the orange tractor tire ballast bookmarked already. I like the idea of rv antifreeze brcause of non toxic. I think isopropyl would be better than ww methanol as far toxicity. I think the lowest the temp at our house gets is around 20.
   / diy tire antifreeze #5
Looks like youv've got a BX? I can't imagine your tires hold enough volume to make it worth your time to mix your own washer fluid. Windshield washer fluid doesn't cost that much to begin with, so you'd only be saving a few bucks, and you would still have to find a way to pump it in there. My dealer filled the rears on my L5740 for $200. It would not have been worth my time to mess with it myself. I'm not sure what percentage alcohol is in washer fluid, but something like 20% comes to mind, which is 25.6 fluid ounces of alcohol per gallon. RV antifreeze costs much more than washer fluid too. Just be careful that you get washer fluid with alcohol in it. Some places (Walmart) carry a "summer blend" that is nothing more than colored water. Good luck with whatever you choose!
I didn't know about summer blend. Thats good info. I have a 1860.
Holy poop $200! I'm too tight to pay that! I enjoy doing things myself. The only thing I have paid for is seamless gutters (takes expensive machine) and a roof (it would take me a year)
   / diy tire antifreeze #8
Here is a chart for Propylene Glycol.. AKA RV anti-freeze. Note as it usually comes from the bottle it is rated to -50 degrees F. So as you can see on the chart this is about a 55 percent solution. So as you can see if you cut this 1/2 and 1/2 with water, you would be at about 27 percent with a freeze point at maybe +12 deg F. Is that enough for your area? On my last tractor I used it straight from the bottle, with 1 gallon in 24 extra pumped in for a total of 25 gallons each tire. In my Kioti I have Methanol solution. as we made a new purchase deal with the dealer. Adding a small amount of isopropanol is not going to lower the freezing point a lot. Ordinary isopropanol is usually 70% straight from the bottle.. Although there are higher concentration blends. You just need to find a chart for it like I did with the RV anti-freeze. Yes a lot of the "summer blend" of windshield washer fluid freezes at +32 deg F.. same as water. Winter blends, some is 0 deg. and some is -20. I have never seen any around here lower than -20 F.
James K0UA
  • propylene glycol freeze chart.pdf
Ok thats helpful. 12 is cold enough. It doesn't get that cold here and tractor is garage kept.
   / diy tire antifreeze #10
That sounds like you would be alright then with 1/2 and 1/2 with water. Just make sure the bottle says -50. The stuff I used did.
53’ STEP DECK  MIXER TRAILER (A45046)
53’ STEP DECK...
2015 EXA INDUSTRIAL PNEUMATIC TRAILER (A45333)
2015 EXA...
2017 Ford Explorer AWD SUV (A42744)
2017 Ford Explorer...
2010 Toro Reelmaster 5610 Fairway Reel Mower (A42744)
2010 Toro...
2004 Ford Explorer 4x4 SUV (A42744)
2004 Ford Explorer...
2011 KENWORTH T800 (A45333)
2011 KENWORTH T800...
