DIY water well drilling rig
   / DIY water well drilling rig #31
Saw this on Ebay - might give you some ideas
This Tractor Rig Is Very Tough, Powerful, And Easy To Use, It Features:
High Torque Hydraulic Drive Motor
High Volume Industrial Water Swivel
Our Water Swivel Seals Are Ten Times As Large And Last Ten Times Longer Than All The Other Swivels Offered In This Class.
Adjustable "Lock-Tight" Slip (Only Available On Our Rigs, We Designed It)
The Beam Angle Can Be Adjusted With Your Tractors Draw Bar
Drill Bits: Our Bits Are Made With Replaceable Carbide Teeth, Very Aggressive, They Will Tear Right Through Clays, Gravel, Sand, And Some Light Sandstone, Hard Rock Formations Require The Use Of Optional Roller Cone Or Diamond Bits.
For More Information On The BoreMaster Hydraulic Operation, Please Visit Our Web Site
This Auction Includes:
PTO Powered, Including Pump, Reservoir, Lines, Ready To Drill
PTO Pump: 540 RPM Pump
(Requires : 1-3/8 6 Tooth Spline Shaft)
Hydraulic Motors: 22 c.i.
Torque: 5200 (in. lb's.)
Double Filter Protection
Primary Hydraulic Filter: 20 Microns
Length Of Stroke: 8 ft.
Pull-Up Capacity: 3000 lb's. Direct Hydraulic
Down Pressure: 3000 PSI Direct Hydraulic
2 Spool Four Way Control Valve
Built-In Hydraulic Fluid Reservoir
Drill Stem: 200 ft. Reinforced High Strength (With Wide Thread Tooled Joints)
Drill Stem Guide / Slip Assembly
Mud Pump: Pull-Start (16000 GPH - 3" Full Trash Pump)
Swivel: High Volume, High Pressure, Rated At 750 PSI
Drill Bits: 2 Bits Total 6-1/2", 9-1/2" (Suitable For Drilling Clay, Gravel, And Some Light Sandstone, Hard Rock, Bed Rock Requires Optional Roller Cone / (Tri-Cone Bits), or Diamond Bits
Pressure Hose: 200 PSI, With Three Way By-Pass Valve
Suction Hose With Strainer
Operational / Maintenance Guides, Well Drilling Manual, Tips and Help Guide
Retail Price: $7,684.00
   / DIY water well drilling rig #32
My guess is that IF you ever make a well that produces usable water that $10-12k will seem like a bargain. I understand about wanting to do things yourself though.
Fwiw that water at 40' is probably very poor quality and may be more affected by seasonal conditions.
We drill a 7" hole for 4 inch casing.
Good luck.
2012 HYUNDAI  HL740-9 WHEEL LOADER (A58214)
2012 HYUNDAI...
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
WATER TRAILER (A58216)
Giyi Excavator Attachment Set (A57149)
Giyi Excavator...
UNUSED FUTURE FT-P45 HYD BREAKER HAMMER (A58376)
UNUSED FUTURE...
20' Sea Container (A55272)
20' Sea Container...
