DK45SE HST Cab - Where to refill Hydraulic Fluid
   / DK45SE HST Cab - Where to refill Hydraulic Fluid #1
stevesdl
Peyton, CO
DK45SE HST Cab
Sorry for sounding incompetent. I am asking for a friend.
Can someone advise where to fill and check hydraulic fluid? This a fairly new machine but a hose had to be replaced and it is now believed that hydraulic fluid needs to be checked\refilled. The basic owner's manual that came with the tractor shows no instructions from what can be discerned.
I have called manufacturer and just get a voice mail to leave info and they will get back.
Can someone please advise exactly where the cap to the hydraulic fluid check\refill is. A pic would be nice if it is allowable here.
Thank you very much
Steve
   / DK45SE HST Cab - Where to refill Hydraulic Fluid #2
Behind the cab, underneath where the PTO and other rear driven implements would attach. On the right side, facing the back of the tractor there is a red rubber shepherd's crook like vent, on a large tube that goes down to the transmission/hydro. Unscrew the rubber vent piece and fill from that location. The opening is about 1.5" across. The dipstick is on the other side of the transmission and has a red colored 3/4" rubber head on it.
Use hydro fluid that is suitable to wet brake systems, UTF, etc. Fill some, exercise the circuit that had the leak, let sit, check level until full on the dipstick.
Thank you very very much!!!
Sending to friend now!
Thanks again
Steve
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A53473)
Neckover GL24-2-7K...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2018 FREIGHTLINER...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB Crane Mechanics Truck (A52377)
2015 Ford F-350...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
