Looking for a blower to mount to my skidsteer.  For budget reasons I'm wanting a tractor unit that's at least 6' wide.  Looked at a two stage unit today, price was right, but there was too much damage to the fan and the unit would extend too far in front of the skidsteer.  Even though he wanted $500 for a 7'-9" 120hp blower, it was just too big of a project to convert it.
Checking Craig's when I got home and I found a 72" single stage blower.  Yea, it's a single stage tractor blower.  The auger is much smaller than the typical tractor blower which is good because I'll be able to see over it.  The blower looks just like the cheap homeowner single stage blower, but it' much wider.  I think this might be perfect for my application, but I have no way to test it.  My only experience is with two stage blowers, so is it possible for a single stage blower to not suck?
Echoing once again what Dave7040 and Fat Tire have said and not liking the bashing of single stage snow blowers I can tell you they are excellent machines, if you have a high volume hydraulic system in your skid steer you can use a Riest single stage snow THROWER(snow caster is the proper term).
The Reist units can also be used with a mules rear 540 RPM PTO system by removing the hydraulic motor, the skid steer quick attach plate and exposing the integral three point hitch and stub shaft for the right angle gear boxes splined stub.
The theee point hitch comes as standard equipment.
The Series 1000 units are base priced at $4,000.00 in canadian loonies the last time I checked and can be brought into the United States with no issues and you will be able to have the canadian sales tax that you paid refunded to you at the border crossing station.
If you do not have enough remote hydraulic power(under 35 gallons per minute) you can also operate it with a hydraulic power pack mounted on the rear of the skid steer loader.
The Reist Units have a roller chain final drive system to power the snow blower rotor which operates at 600 RPM at  540 RPM PTO speed if I remember correctly. the snow blower rotor speed can be changed with simple hand tools by changing either one or both drive and driven gear tooth sprockets.
A small single stage snow caster like the Reist series 1000 will never run out of power as long as it is used correctly for the conditions and it requires very little work to repair or replace a broken roller chain.
You can always have them make the chute longer to reduce snow spray and add lights to the chute as well at an extra cost.
The chain guard for the roller hain drive is simply a door mounted on hinges and opened by removing the pin that holds the access door shut.
The Reist Single stage snow throwers have a lot of steel in them  and are very well built just like the old IHC cub cadet single stage snow throwers. The one I had on our 1967 12 horse cub cadet lawn tractor was a beautiful snow thrower and never gave us any trouble.
I have a picture of a hydraulic drive Reist Series 1000 and 2000 and picture of their separate hydraulic pump and drive system mounted on a tractor.
