Do all t190's come standard with high flow.
   / Do all t190's come standard with high flow. #1
Jayfish
753 bobcat
Looking at a nice t190 made an offer- but I am needing to know if high flow is standard on a t190 or an option. I pushed the high flow button and it didn't light up. Any thing particular I have to do? Will it only light up with something attached to hydraulics? How can I test Or find out if it has high flow.
Need to know ASAP cause I'm trying to seal a deal!!
Thanks all!
   / Do all t190's come standard with high flow. #2
Thanks all!
High flow is an option.
   / Do all t190's come standard with high flow. #3
My T190 also has the high flow button, but it does not light up.
Can high flow be added for a reasonable cost?
   / Do all t190's come standard with high flow. #4
That means that you only have standard flow.
   / Do all t190's come standard with high flow. #5
   / Do all t190's come standard with high flow. #6
You woul have to buy a new 3 section pump (discard the perfectly good 2 section that is on ther now or sell it on ebay), also need the Hi-flow diverter valve and all auxilary plumbing from control valve to rear of machine where goes up to the lift arm, plus I believe the Hi-flow uses a larger oil cooler and larger retrun lines. It can be done, but ain't cheap.
After it is install, the dealer needs to reprogram the machine to tell it it is equiped with Hi-flow so you dash button works.
2016 Caterpillar 349FL Hydraulic Excavator (A53421)
2016 Caterpillar...
2011 Ford Escape XLT SUV (A54815)
2011 Ford Escape...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
2012 DOOSAN G25KW GENERATOR (A53843)
2012 DOOSAN G25KW...
New/Unused IRGC40 Mini Golf Cart (A54865)
New/Unused IRGC40...
2011 FONTAINE 48 FOOT STEPDECK (A53843)
2011 FONTAINE 48...
