Volfandt
Veteran Member
Good answers. I'll just add my $0.02 too. A good rule of thumb w/any tractor, don't park it on a slope
A runaway tractor isnot a good thing
If you can't avoid it, drop the FEL and/or implement to help hold it in place.
HST's by their very design will creep. There is a sweet spot in an HST where the swash plate can rest in a position where it isn't putting enough fwd or rev pressure on the hydraulic motor to move the tractor and this is where every manuf trys to set it's neutral postion, thing is linkages wear as does the bearings, raceways etc., and it only takes a fraction of an inch for the neutral position be, well, not neutral. Theres adj's to every HST motion pedal/lever to get back to the neutral position but I wouldn't depend up the tractor sitting perfectly still just by placing the motion pedal/lever in neutral. To be safe, always set the brake if you want the machine to remain still and drop the implement(s) if you want it to stay put with the engine running for a longe period of time.
Good luck
Dave
Good luck
Dave
