Do I need a hitch that distribute. The load to keep my truck from sinking to much.
   / Do I need a hitch that distribute. The load to keep my truck from sinking to much. #21
After looking at the pic, I don't think you're going to get that tractor with an implement on that trailer - not balanced, anyway. You need at least a 20-foot trailer. I also believe that the load is not within the tow specs of your pickup. Please check the rating on your hitch, also. Many factory hitches are only rated for 6,000 lbs even on vehicles rated to tow more than that.
You didn't mention your brake controller. Please invest in a proportional controller. It is one important key to towing safety. Google the difference between proportional controllers and time-delay controllers.
Better to ask than to get yourself in trouble.
Ahh- you got no problems. Just load em both an a lowboy.
OK just loan me the money for the trailer and truck to pull it.
   / Do I need a hitch that distribute. The load to keep my truck from sinking to much. #24
Everything is getting old!!! I will call for a price today for new leafs.
Either way you still need a Weight Distribution Hitch.
If the truck and trailer are not up to the task you need to upgrade or forget towing it until you can afford to do so.
Can
   / Do I need a hitch that distribute. The load to keep my truck from sinking to much. #25
i load my trailers so that the bumper of the truck only drops down about an half to an . inch more than the trailer fenders go down. this i think gives you just about the right amount of tongue weight. has always worked for me, and i have towed a LOT of different weight things and trailers.
I have another question now how important is the 60 40 rule if I just add 2 feet and 2 feet for the dove tail?. Will that really matter for just 4 feet.
   / Do I need a hitch that distribute. The load to keep my truck from sinking to much. #27
If you add 4' you'll probably be in the 50/50 range. Having a longer tail may cause the trailer tail to drag under certain driving conditions such as uneven terrain. You would also increase tail swing when going around corners. If adding 4' to the tail the axles should be moved to keep the 40/60 aspect.
It may be easier to sell your trailer and buy one the length you need.
Sounds like it I have it on CL. I was just wondering what I had to do if it doesn't sell.
   / Do I need a hitch that distribute. The load to keep my truck from sinking to much. #29
Around here a solid used trailer will sell for a price very close to a new one. Good luck with the sale. Trailer prices are crazy high lately - like everything else.
Thanks a lot is just the people on CL. Are cheap!
2009 GMC C5500 Landscape Truck (A56858)
2009 GMC C5500...
2015 INTERNATIONAL FLATBED (A58214)
2015 INTERNATIONAL...
2017 Ford F-450XL (A57148)
2017 Ford F-450XL...
Set of Heavy Duty Steel Trailer Ramps, 60" Long (A59076)
Set of Heavy Duty...
2015 GMC Terrain SUV (A56859)
2015 GMC Terrain...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
