Do I need to bleed my Hydraulics and How?
   / Do I need to bleed my Hydraulics and How? #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
As I posted in another thread, I had my tractor, including the hydraulic system, torn apart for almost a month. It's all back together again, but now what do I do with the hydraulic system?
I drained at least a gallon of fluid. After putting new fluid in, do I need to bleed the system? How do I do this?
I've got a 3 point hitch and an aftermarket front end loader that run off the hydraulic system.
   / Do I need to bleed my Hydraulics and How? #2
You don't do anything different than when you change your hyd fluid & filter.
Just fire it up and run everything through their paces. Any air in the system will work its way out.
I was hoping someone would say that.
   / Do I need to bleed my Hydraulics and How? #4
Gday, Just something else to add, Both the loader and the 3 point hitch have single acting rams so make sure both are at their lowest position befor topping up the hydraulic oil.
If you have a hydraulic ram on your bucket then this is double acting so it dousent matter what position it is in, It wont affect the oil level.
Cheers
Roscoe
Single acting? Double acting?
Maybe I understand this wrong.
I know I can lift the front tires off the ground by tipping the bucket down and then putting the lift arms all the way down. I thought this could only be done with a double acting ram.
Help me out. What's the difference?
   / Do I need to bleed my Hydraulics and How? #6
Most likely only the 3ph is single. Doesn't have "power down" does it?
No power down.
WHITCO PRESSURE WASHER AND STEAM CLEANER (A53843)
WHITCO PRESSURE...
2 - SIDE MOUNT TOOLBOXES (A53843)
2 - SIDE MOUNT...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
JOHN DEERE 3032E TRACTOR (A54756)
JOHN DEERE 3032E...
2007 Fontaine Trailer (A52377)
2007 Fontaine...
