Do I really need trailer brakes?
   / Do I really need trailer brakes? #41
   / Do I really need trailer brakes? #42
Even brakes on one axle makes a huge difference!
I always test my brakes when I hook up because I set them different when loaded or empty.
My Reese Controller has manual application lever, amount of braking pressure adjustment and slow-to fast application adjustment.
It really does feel a lot safer towing with the brakes.
This trailer has all 4 wheel brakes on it.
   / Do I really need trailer brakes? #43
A slightly related issue I've never been able to understand. It appears almost all states require brakes on larger trailers, yet you can buy them without brakes. Why is that? My 7K trailer was used when I bought it and it apparently had never had brakes. I put brakes on one axle immediately but wasn't really comfortable with it and later added them to the other axle. I can't imagine having that trailer long term without brakes because it really isn't right without brakes on both axles..
   / Do I really need trailer brakes? #44
My car hauler trailer only weighs 1500 pounds. I could tow an Ariel Atom on it and still be legal without brakes.... if I could afford an Ariel Atom! :laughing:
   / Do I really need trailer brakes? #45
D*mnit man, I was about to ask if you owned an Ariel Atom.
   / Do I really need trailer brakes? #48
My trailer and an awful lot I see for sale only have brakes on one axle. According to the the AAA link (Thanks Qapla) "GEORGIA Every trailer of 3,000 lbs. GVWR or more must be equipped with brakes on all wheels."
So my trailer is not legal? How hard is it to add brakes to that axle? Just replace the whole axle?
   / Do I really need trailer brakes? #50
Depends on the type and make of axle. If there are backing plates, you usually can just buy a kit and bolt them on.
Heavy Duty 72in Brush Cutter Skid Steer Attachment (A55787)
Heavy Duty 72in...
2014 Wacker BPU 3545A Reversible Vibratory Plate Compactor (A55787)
2014 Wacker BPU...
2018 Kenworth T680 Tri- Axle 20 Yard Dump Truck (A55788)
2018 Kenworth T680...
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
1994 International 3800 Bus (A54814)
1994 International...
Cast Iron Mailbox (A55758)
Cast Iron Mailbox...
