Do rotary cutter blades need sharpening?
   / Do rotary cutter blades need sharpening? #1
Bob77064
Elite Member
KY @ TN line
2011 LS R3039
Do the blades on a rotary cutter ( bush hog ) need to be sharpened?
   / Do rotary cutter blades need sharpening? #2
Yes but not like lawn mower blades. Most OEM's recommend a rather blunt 1/8" radius on the leading edge of the blade tip. If they are ground too sharp, the blade tends to tear when it hits a rock the the resulting crack can lead to a blade failure which will be uncontained by the mower housing. If they are really dinged up they should be replaced.
Thank you for your help. So far after breaking two shear bolts they still look good.
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A52128)
2004 Capacity Yard...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
**SALE ORDER ANNOUNCEMENT** (A51242)
**SALE ORDER...
2014 International Durastar 4300 Terex BT2047 47ft Crane Truck (A50323)
2014 International...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
