Do rotary cutter blades need sharpening?
   / Do rotary cutter blades need sharpening? #1
Bob77064
Elite Member
KY @ TN line
2011 LS R3039
Do the blades on a rotary cutter ( bush hog ) need to be sharpened?
   / Do rotary cutter blades need sharpening? #2
Yes but not like lawn mower blades. Most OEM's recommend a rather blunt 1/8" radius on the leading edge of the blade tip. If they are ground too sharp, the blade tends to tear when it hits a rock the the resulting crack can lead to a blade failure which will be uncontained by the mower housing. If they are really dinged up they should be replaced.
Thank you for your help. So far after breaking two shear bolts they still look good.
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
2019 GALYEAN...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2016 Cat TL1055D Telehandler (A56438)
2016 Cat TL1055D...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
