Do you do a 50 hr oil change for a new rotacutter gearbox ?
   / Do you do a 50 hr oil change for a new rotacutter gearbox ?
It's not uncommon to have clean oil, as really there is not much that can get in there, the process of changing it is really to keep it fresh, it also gives you an opportunity to check for ware, I.e metal filings coming out with the oil. Really they use so little and oil is cheap, so no harm in doing it!
All this said I know many gearbox's that haven't seen oil in 30 years, and they are still crunching away!
Hung the slasher on the loader and finally got some metal filings (not a lot) from the oil that was sitting at the bottom of the gearbox. Thanks again for the help.
   / Do you do a 50 hr oil change for a new rotacutter gearbox ? #12
I changed my Bx24 front diff fluid at 50 hours, bad, with Amsoil SS gear. Also did the mowe deck too. Now the front sweep still has orginal fluid, aka not used much.
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
Case 1083 20ft Corn Head (A55301)
Case 1083 20ft...
2014 VOLVO A25G ARTICULATED DUMP TRUCK (A51406)
2014 VOLVO A25G...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
