Do you grease your 3 point hitch swivels?
   / Do you grease your 3 point hitch swivels? #1
bx24
Platinum Member
Indiana
Up until now, I have not added any lubrication to my 3 point hitch friction points (pins, ball swivels etc). I have heard the arguments go both ways:
Don't because:
Oil / Lube attracts dust and eventually only makes things worse
Do because:
Keeps things from sticking and makes movement easier
What are the rest of your thoughts?
Paul
   / Do you grease your 3 point hitch swivels? #2
I wipe mine with a thin coat of never seeze. Dirt and dust wash off when I wash my tractor and everything keeps moving like it is suppose too. I also twice a year take top link, lower link, and any other threaded connection apart to clean and never seeze again.
Peter
   / Do you grease your 3 point hitch swivels? #3
One of the tractors I use is 35 years old. I don't believe the ball swivels have ever been greased. They work fine.
   / Do you grease your 3 point hitch swivels? #4
I like to light oil the balls and wipe the excess off every time I change an implements. No major wear noticed to date on my Kubota(s) or my JDs for that matter.
   / Do you grease your 3 point hitch swivels? #5
My dealer hoses them down with white lithium whenever I take it in for service. Not sure if it is good or bad. Seems to stay sufficiently lubricated and not attract a gross amount of gunk, so I just do that every month or two. Whenever the mood strikes me.
   / Do you grease your 3 point hitch swivels? #6
I use liquid graphite so as not to attract dirt. The carrier dissolves leaving only the graphite which is an excellent dry lube. But then, how can you argue with a 35 year old tractor whose swivels have never been lubed and still work? Have no idea which way is best so I guess it's whatever turns your gears.
I forgot to mention when I started this link that I went ahead and brushed on some white lithium grease on them. I think I will go the route of occasional lubing and wiping off the excess.
I worked at a garage where the guy cut a small 1/4" hole or so in the top cover of a grease tub and left a small brush (the kind with the hollow metal handle) always stuck through the hole. It worked so well I have not been without my own since then (25 years later). I use it to quick lube studs and other bolts that I would prefer come apart later without the rust. Reply if you want a picture but I think you guys get the idea
   / Do you grease your 3 point hitch swivels? #8
Greetings;
I'd have to put myself in Studway's camp. My 56 year old Ford's swivels have never see a drop of lube and they are fine.
Cheers, Erik
   / Do you grease your 3 point hitch swivels? #9
1953 Ford Jubilee and have never lubed. Work just fine.
   / Do you grease your 3 point hitch swivels? #10
I pretty much give everything that is not orange and gray a good coat of WD 40. Usually 1 per month and then 2 heavy coats before winter salt arrives on the roads. Everything on the underside looks as good as new including 3 PT hitch balls and all pins.
Jeff
202475 (A54757)
202475 (A54757)
2019 Ford F-550 (A55973)
2019 Ford F-550...
Set of 4 12-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 12-16.5...
2012 Ford F-250 4x4 Ext. Cab Pickup Truck (A56858)
2012 Ford F-250...
2017 Ford F-550 4x4 Crew Cab Stellar 7628 7,500lb. 3.75 Ton Crane Service Truck (A55973)
2017 Ford F-550...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
