Do you grease your 3 point hitch swivels?
   / Do you grease your 3 point hitch swivels? #11
I'm not sure about using grease to protect the parts, but it sure makes it alot easier to attach and remove the implements, in my experience.
Regards, Mike
   / Do you grease your 3 point hitch swivels? #12
wnymudd said:
1953 Ford Jubilee and have never lubed. Work just fine.
Maybe it's a Ford thing. Mine is a 1972 Ford 5000.
I think it's safe to say that if someone wants to lube, grease, or spray the ball swivels they can, and it may make implement changes easier, but if you don't it's no big deal.
   / Do you grease your 3 point hitch swivels? #13
Ob1kubota said:
I like to light oil the balls and wipe the excess off every time I change an implement..
umm... I sure hope we're still talking about hitches here...
Anyway, I like the graphite lube myself... just haven't gotten around to it for this yet. Maybe someday. Or not.
   / Do you grease your 3 point hitch swivels? #14
I had some white lithium spray lying around and squirted some on the hitch balls. All it did was collect dust and dirt and hold it there.
Now I just give them a squirt of WD-40 to loosen them up when its time to change implements. No more grease for me.
   / Do you grease your 3 point hitch swivels? #15
WD-40 stands for "Water Displacement, 40th attempt.
Main ingredients, from the material safety data sheet, are:
* 50%: Stoddard solvent (mineral spirits, also commonly known as dry cleaning solvent)
* 25%: Liquefied petroleum gas (presumably as a propellant, carbon dioxide is used now to reduce considerable flammability)
* 15+%: Mineral oil (light lubricating oil)
* 10-%: Inert ingredients
WD-40 is not a very good lubricate, in fact it cleans most lubrications away. I used it on desk drawer glides and file cabinet glides for a large bank at there branches to stop squeaks. About a year later I began replacing the glides because they wore out from lack of lubrication. The ball bearing glides would self destruct. It was good job security for me.
It does have a lot of uses, but lubrication is not one. IMO:rolleyes:
Cary:cool:
   / Do you grease your 3 point hitch swivels? #16
Agreed...for one, it evaporates fairly readily. I think it's being used for its solvent properties in this application, not being relied on as a long-term lubricant.
   / Do you grease your 3 point hitch swivels? #17
That's correct. It frees them up, gets in moisture out and makes it easier to switch implements. And it clearly provides some level of lubrication, but only for a very short while. To me, that fact that it essentially evaporates is a strength, not a weakness. Anything that sits there is going to collect dirt and dust....which become abrasives.
   / Do you grease your 3 point hitch swivels? #18
Cary:cool:
I thought it had fish oil in it... That's what makes it taste so good on ice cream!
   / Do you grease your 3 point hitch swivels? #19
I spray mine with liquid graphite, same on the folding ROPS hinge points.
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD72...
SIDE BOX (A55745)
SIDE BOX (A55745)
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
2015 Ford F-750 Stellar 10628 10,000LB 5 Ton Mechanics Crane Truck (A55852)
2015 Ford F-750...
