Do you have the Harbor Freight 15KW PTO Generator? What do you think?
   / Do you have the Harbor Freight 15KW PTO Generator? What do you think? #61
Please don't bite my head off. Most gas and diesel engines have governors. Even my 1948 8N has a governor. When there is more electrical demand, the engine uses more mechanical energy, and fuel usage increases in order to keep a constant rpm. When there is less electrical & mechanical demand the engine takes less fuel to keep the rpm constant.
In the case of my 2320 I believe the throttle and my hand is the governor. I realize diesel and gas generators have built in governors.
VP
   / Do you have the Harbor Freight 15KW PTO Generator? What do you think? #62
Sorry about the double post, I'm learning!
   / Do you have the Harbor Freight 15KW PTO Generator? What do you think? #63
I did a bit of research on PTO generators & I emailed HF with a few questions. A few things I liked were the GFI 120 volt outlets. The automatic voltage regulation module. Price. Also, what I found out about brush vs non brush seemed not to matter too much, the brushes are for the control voltage, not the output voltage, unlike the old brush motors. Here is a link for an interlock kit, does the job of a transfer switch manually, at a much lower cost: National Ram Electronics
Here is a edited email that I got from HF:
Thank you for your email inquiry. The part you are inquiring about is not stocked in the warehouse and will need to be special ordered from the manufacturer. This order process can take approximately 6-8 weeks for delivery. If you have any questions or would like to place an order for the part, you can call toll free at 1-888-866-5797. If you chose to send in a check, please ensure you include shipping and tax with the total cost. Our shipping rates can be located at Harbor Freight Tools.
Do you sell replacement brushes?
VENDOR PART DESCRIPTION PRICE
61 CARBON BRUSH WITH HOUSING $9.90
What country does the generator head come from?
This unit originates in China.
What is the total harmonic distortion in percent?
THD < 5%
Does the generator ship on a standard pallet?
Yes, this unit does ship on a standard pallet.
Is there any way that I can see one of these generators before I buy one?
You may be able to view this unit in a local store, but you will need to contact your local stores to check availability/inventory.
(Note: Every time I call a store, they say it is catalog only!)
With the generator on the 3 point hitch stand, what is the height above
ground of the input spline?
The measurement you were looking for (ground to shaft) is approximately 24".
Can I apply one of the 20% off coupons on this item?
(Note: There was no answer to this question, but I think we all know the answer to this one--NO.)
We do apologize that it took so long to get back to you. Please advise if we can be of further assistance.
Customer Service Dept.
HFT Tech Support
888-866-5797
tech@harborfreight.com
How much too short is the supplied pto shaft? I also have a L4400 (HST). If the shaft is only short by a few inches, what about adding one of the drive shaft extensions, or a slip clutch, or an over running clutch? Extension Adapter - 0271033 | Tractor Supply Company I'm glad you posted your comments, now I know if I buy a HF generator the pto shaft is too short, but not by how much. Thanks http://www.tractorbynet.com/forums/images/smilies/new/dance1.gif
I have quick hitches that move the implement back about 4". If I did not have the quick hitch using a PTO extension may work but because the BX1500 uses the shorter shaft it will require a different shaft for each tractor.
   / Do you have the Harbor Freight 15KW PTO Generator? What do you think? #65
How can that be variable if the tractor RPM stays constant? There is no governor.
VP
on a diesel, your IP should contain what amounts to a governor.
and yes.. fuel usage is based upon load.. not specifically rpm..
mowing 7' tall grass at 540 pto rpm uses lots more fuel than triving around mowign NOTHING at 540 pto rpm.
it's just simple physics.. no free lunch.... :)
   / Do you have the Harbor Freight 15KW PTO Generator? What do you think? #66
What is IP? It seems I have to adjust the throttle myself, under a load the RPMs drop.
VP
   / Do you have the Harbor Freight 15KW PTO Generator? What do you think? #67
VP
I'm jumping back in here. The IP is the Injector Pump. This is a link to what should be a manual for your Yanmar engine:
http://www.masenorthamerica.com/Manuals/DM/DSM-Y Model TNE.pdf
In section 13, the governor & injector pump are shown. I suggest leaving governor and especially injector pump work to someone that has done this type of work before & know what they are doing. I got the manual from this link:
[PDF]
YA N MA R
www.masenorthamerica.com/.../DM/DSM-Y Model TNE.pdf
File Format: PDF/Adobe Acrobat - View as HTML
This Service Manual describes the procedure of maintenance and service of the Yanmar industrial. TNE series engine ..... 13-1 Exploded views of governor for indirect injection system . ..... out U1... rating "W(HP) (12.2) (14.5) (24.1) (25.2) ...
Please verify that this manual is for your engine. I do not know much about the newer JD tractors & Yanmar engines. Hope this helps.
   / Do you have the Harbor Freight 15KW PTO Generator? What do you think? #69
[PDF]
YA N MA R
THE 2320 USES A 3TNV76
   / Do you have the Harbor Freight 15KW PTO Generator? What do you think? #70
I will do some throttle experiments and see what happens.
VP
2023 JOHN DEERE 8R310 LOT NUMBER 202 (A53084)
2023 JOHN DEERE...
2023 JOHN DEERE 8R340 LOT NUMBER 221 (A53084)
2023 JOHN DEERE...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51246)
2019 CATERPILLAR...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
2019 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2019 PETERBILT 567...
