Do You Remove TnT for Some Impliments ?
   / Do You Remove TnT for Some Impliments ? #21
Just the backhoe for me since the entire 3 pt has to come off my JD3320 for it. No big deal though, maybe 10 minutes to remove everything?
   / Do You Remove TnT for Some Impliments ? #22
Is this because your top link cylinder drifts or doesn't hold or is there something else about it I need to understand ? If it is a drift problem how long will it hold before you have trouble ?
Thanks for the input.
It's not the top link that is the problem with the disc mower. It's the tilt cylinder.
Yes, the cylinder "drifts" during the course of a day of mowing. When you stop for any period - lunch, fuel, plugged cutter bar, etc. and you shut the tractor down - the weight of the cutter bar will pull the cylinder down.
Then you have to re-adjust the cylinder. Of course, anytime you switch the hyd functions between the top or the tilt that can affect the cutter bar angle, etc. So, I find myself having to "fiddle" with the adjustment too often and it becomes a PITA.
I leave the hyd top link on the tractor while mowing - but I bought a standard "hard" link for the 3pt tilt and use it when using the disc mower.
Just the opposite situation with the hay rake. Drop the top link for the "hard" top link. The rake has dual wheels so, the tilt issues don't seem to be as much of a problem.
AKfish
Thanks for explaining that AKfish
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2018 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2018 Allmand...
Unused 2025 LandHonor LDH-KN16 Mini Excavator (A52377)
Unused 2025...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
FORD F150 TRUCK (A54756)
FORD F150 TRUCK...
