Do you use a synthetic transaxle/hydraulic oil?
   / Do you use a synthetic transaxle/hydraulic oil? #21
<font color="blue"> I suspect all our compact tractors would be set up similarly. </font>
Most are that way, but there are some where the loader valve doesn't have PBY and then the backhoe has the PBY. I just don't have one of those scanned in.
That diagram still leaves me with some questions. For instance, the "return" line that just sort of ends after the BH doesn't really define what it is. It doesn't show that it connects back to the sump.
Also, you will notice that the first two valves have three connections, power (P), power beyond (PB, they call it Bypass, but I like the Power Beyond name better, seems more meaningful), and tank (or sump) return (T).
These all make sense. But the backhoe (BH) valve only shows an inlet and outlet. That's fine, but they don't define or show in the valve schematic what the "outlet" is. Is it a PB (pressurized), or T (sump return)? Or maybe more likely, does the valve internally combine the two outputs into one low pressure return that should connect to the sump? You have to have someplace for fluid to go both when the valve is not active and when it is active, in the former case it will have the same pressure that is at the inlet, and in the latter case it had better not be connected to pressure or the work cylinder will not be able to get any work done.
If this schematic showed the outlet of the backhoe valve connecting up to the sump, it would make more sense to me. That return line can't just go nowhere or have a cap on it or the pump will kill itself pretty quickly.
By leaving the sump and the pump out of the diagram, and lines just floating in space, I am left with some unexplained questions. I also like the John Deere manual's hydraulic diagrams where they always show pressurized lines in red, and low pressure lines in blue.
   / Do you use a synthetic transaxle/hydraulic oil? #23
<font color="blue">the "return" line that just sort of ends after the BH doesn't really define what it is. It doesn't show that it connects back to the sump.
</font>
On this tractor the return goes into a block which feeds pressure into the three point hitch.
<font color="blue"> Also, you will notice that the first two valves have three connections, power (P), power beyond (PB, they call it Bypass, but I like the Power Beyond name better, seems more meaningful), and tank (or sump) return (T) </font>
It really doesn't matter, because different manufactures use different terminology. If you are going to work on hydraulics, it is just one of the thinks that you have to learn.
<font color="blue"> But the backhoe (BH) valve only shows an inlet and outlet. </font>
That is all that it needs, it's the last valve in the system.
<font color="blue"> Is it a PB (pressurized) </font>
As the last valve in the system it doesn't need a PB. It just has to be a open center valve.
<font color="blue"> That return line can't just go nowhere or have a cap on it or the pump will kill itself pretty quickly. </font>
I didn't include part of the drawing in an effort not to confuse to many. I was a tempting to make it more generic.
<font color="blue">By leaving the sump and the pump out of the diagram, and lines just floating in space, I am left with some unexplained questions. I also like the John Deere manual's hydraulic diagrams where they always show pressurized lines in red, and low pressure lines in blue. </font>
Same as above. I have posted the connections part of the diagram above.
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
Unused Delta Crash...
CONTACT INFO (A53084)
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
