Dodge 6.7 Cummins
   / Dodge 6.7 Cummins #11
KICK said:
Yea, urea maybe the future. However, the dodge cummins 5.7 is suppose to be 2010 compliant as it is with out the use of urea. Urea is suppose to reduce the (NOX?) emissions. Europe is more stringent than here which is why no one uses urea yet. I read that dodge uses some type of special metal/catalyst in their DPF to make it 2010 compliant. It reportedly makes the DPF more expensive than what ford or chevy use. I heard a ford DPF costs about $1000.
   / Dodge 6.7 Cummins #12
Over here in Europe, you see AdBlue (which is a trade name for urea) tanks popping up all over the country, allmost every self respecting gas station has one as 80% of new heavy trucks need urea to get to Euro 5.
With the use of urea, the fuel consumption was lowered by about 10 to 15% (compared to Euro 3 engines which didnt use it) because motor makers can adjust their injection pumps for maximum fuel efficiency and let the urea take care of the emissions afterwards.
   / Dodge 6.7 Cummins #13
Interesting. It maybe cheaper to add urea and offset the cost of the urea with better fuel economy from the diesel engine. I think by 2010, urea maybe the solution in the states.
   / Dodge 6.7 Cummins #14
Urea injection is a very reasonable technology. The main hurdle in the US is the general assumption, unfortunately probably correct, that too many of our drivers are stupid or lazy and will refuse to refill the urea tank when it needs it. This doesn't inherently disable the engine, but it would make emissions go through the roof. As a result, it's likely that the engine computers will be set to go into limp-home mode if out of urea. That in turn would make most US buyers unhappy.
   / Dodge 6.7 Cummins #15
Well, most buyers don't forget to fill the fuel tank, right? If they do, they don't get a limp home mode, they get a walk home mode.
The current system is questionable to me. I have to burn ULSD which gives me less MPG, increasing my reliance on imported fuel that is more expensive and needs an additive to make my truck run well. [at least that is what my Ford mechanic tells me to do and I do feel a difference.]
If the urea boosts mileage, why aren't we doing that? I have heard the urea tank needs a refill every 30k miles or so. So what - I get my vehicles serviced that often and more. It can't be very expensive since they spread it on corn fields to make ethanol.
I'm all for saving the earth and the fuzzy critters on it but I'm keeping my polluting Powerstroke until someone figures out the right, simple thing and proves it works reliably. I'm tired of the dumbed-down lawyered-up solution for Americans.
{rant mode off}
   / Dodge 6.7 Cummins #16
You would still need ULSD with a urea system. Higher sulfur diesel is not coming back.
From what I've read urea tank refills will be a lot more often than 30k miles. If they do turn out to be that infrequent, that's great! No, urea should not be very expensive, unless the dealers/mfrs find some way to charge 10x what it should be because they control the supply of the only fluid meeting the manufacturer's specs.
I have not noticed any decrease in mpg with my two diesel vehicles, which I owned for about 9 months before ULSD came into my area. Also, both of them are running better now than with LSD.
Personally I find the 2005/06 model diesels to be quite clean when running on ULSD, and I don't like the 2007+ emissions rules for their blanket application across the US.
   / Dodge 6.7 Cummins #17
It doesn't really boost mileage. It just doesn't hurt mileage like some other emission reduction methods do. The urea is injected into the exhaust, so it doesn't affect the way the engine runs. It just allows you to run at a higher combustion temperature (which is more efficient) without producing unacceptably high NOx emissions.
   / Dodge 6.7 Cummins #18
As I have stated in previous posts, my new Ford 6.4L diesel gets exactly what, if not slightly better than, my old 7.3L did and gets better than many of my colleagues that run the 6.0L. I am getting on average about 1/2 mpg more than my friend's post emissions Duramax but it is close. I cannot say go diesel based on economy alone, but how many of us would really do that anyway? As for the one posters comment about the Cummins and Duramax engines being favorable over the new Ford, this simply is not the case. They are all excellent engines and the Cummins issue I am sure will be sorted out quickly. As each offers great performance I would go with whichever is attached to the truck one wants.
John M
   / Dodge 6.7 Cummins #19
What is a large component of mammalian liquid nitrogenous waste? What is one of the two blood tests ordered to check renal function? What are we going to put into the second tank on future diesels? Why should any company corner the market and patent the additive when we have our own recycling equipment "on board?" Why, it would down right cheap to refill the urea tank :)
2007 FORD F-150 XL TRITON (A55745)
2007 FORD F-150 XL...
2015 Ford F-750 Stellar 10628 Mechanics Crane Truck (A55852)
2015 Ford F-750...
Case SR200 Skidloader (RUNS) (A50775)
Case SR200...
UNUSED AGT TAS-50X PTO Driven Tiller (A47477)
UNUSED AGT TAS-50X...
2015 Freightliner M2 106 Altec Insulated Forestry Bucket Truck (A55788)
2015 Freightliner...
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
