Does your 3 point post hole digger dig down 3 feet straight?
   / Does your 3 point post hole digger dig down 3 feet straight? #31
I just creep forward with the HST to keep the auger vertical as it digs down. Usually works fine.
   / Does your 3 point post hole digger dig down 3 feet straight? #32
   / Does your 3 point post hole digger dig down 3 feet straight? #33
Road burns.
Bruce
That is an old report...1996. I believe that the original issue was iron remnants (remains of steel belts) that got wet, oxidized and heated up, setting the rubber on fire. Not really an issue these days as technology is better at removing the steel and people are better at keeping stores dry.
Rubber asphalt mixes are used on most of the interstates around here; it drains water faster, and is quieter than concrete or asphalt. (y)(y)
All the best,
Peter
   / Does your 3 point post hole digger dig down 3 feet straight? #34
I haven't seen rubber either but certainly sounds interesting, recycled tyres are used for road resurfacing to playground surfacing, much different density between the two with the latter being soft, feels like walking on a firm sponge, idea was to save little arms and legs from breaking when falling off equipment, road surfacing is mixed with other materials.
They tried some rubber roads here.... they caught on fire
   / Does your 3 point post hole digger dig down 3 feet straight? #35
   / Does your 3 point post hole digger dig down 3 feet straight? #36
I only have a 16" bit so whether I am putting down a 8"x8" concrete post or a 4" treated round, the big hole allows me to get the post vertical. Lots more backfilling by hand but it works for me.
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
2021 MACK GRANITE TRI AXLE DUMP TRUCK (A52576)
2021 MACK GRANITE...
2001 STERLING DUMP TRUCK (A54756)
2001 STERLING DUMP...
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
2011 Nissan Maxima Sedan (A53424)
2011 Nissan Maxima...
