Does your dealer send in for an oil analysis when your machine gets serviced?
   / Does your dealer send in for an oil analysis when your machine gets serviced? #11
Well, you don't really say, but there is engine oil and hydraulic oil. Analysis
of the latter oil would be much more interesting and cost effective for
your tractor, esp if you have an HST. That stuff is often more than $10
per gallon and you need 7-10 gallons for many CUTs. At a typical
change interval of 400h, I know it is not done often, but extending
that interval could be justified, depending on the analysis.
This has been discussed on TBN before, but I have yet to see the results
of a hyd oil analysis posted.
I buy it in 5-gallon buckets. It's $102 + 4% tax up here for JD 20C.
AKfish
   / Does your dealer send in for an oil analysis when your machine gets serviced? #12
With CAT it's automatic out here. Great service technique when you think of it.
   / Does your dealer send in for an oil analysis when your machine gets serviced? #13
   / Does your dealer send in for an oil analysis when your machine gets serviced? #14
Sure, hundred grand engines and trannys. But the OP is talking John Deere compact.
//greg//
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
2012 Hitachi PC138 (A47477)
2012 Hitachi PC138...
