Does your fuel gauge actually work?
   / Does your fuel gauge actually work? #23
Fuel gauge is fine on mine. Yes, it stays at F or above for the first couple gallons, then it drops quick. Not an issue, when I am at 1/2 tank or a little less it takes 5 gallons. When it's all the way down to E it takes 7-8. I prefer that to sputter sputter shake stop.
   / Does your fuel gauge actually work? #24
Fuel gauge yes, temp not so much.
The way to get the temp gauge to move off 1/4 is to bush hog or mow really thick and wet grass for long periods. It helps if the grille in front is partly packed with grass clippings. It's the only way I ever got the gauge to move.
   / Does your fuel gauge actually work? #25
L2800 gauage doesn't show the correct level of fuel in tank,thats okay because I diesel up most everytime before use...learn that from Farmall H many years ago. ;)
   / Does your fuel gauge actually work? #26
My BX24 gauge stopped working and I traced it to a ground at the left rear. Worked fine since but it does fluctuate a little on rougher ground. Lets me know whenI need to come in and fill OK.
   / Does your fuel gauge actually work? #27
i just replaced my temperature gauge Saturday now they all work.
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2019 VOLVO VNR TANDEM AXLE MID ROOF TRUCK (A56129)
2019 VOLVO VNR...
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
(INOP) POLARIS RANGER 900 RTV (A54756)
(INOP) POLARIS...
2021 New Holland C327 Compact Track Loader (A55302)
2021 New Holland...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
