Does your tractor have a kill switch under seat?
   / Does your tractor have a kill switch under seat? #31
Nope, no kill switch under the seat..
   / Does your tractor have a kill switch under seat? #32
Yup and my Deere works pretty simple too for running the PTO off the tractor, tilt the seat forward and pull up on the switch. No other interlocks like the new ones have.
My big problem is a really need a new seat soon. :eek:
It's definitely falling apart after 15 years and even though I drilled and riveted new mounting brackets to the seat pan they just don't hold that tight after a while and so when the seat flexes a little when I move around a bit too much engine dies...if I don't move my position back quick! :D
   / Does your tractor have a kill switch under seat? #33
My bx 24 has one , when I ran a chipper , I just put a cinder block n the seat . Worked .
   / Does your tractor have a kill switch under seat? #34
Try a squeeze clamp on the kill switch. Put it on prior to engaging the pto.
   / Does your tractor have a kill switch under seat? #35
Tilt the seat forward as you are getting up, and off the tractor...
I've killed the engine as many times as I remembered to do this...
correct, you have about a second before engine dies to tip the seat
   / Does your tractor have a kill switch under seat? #36
My TYM233 has a seat interlock that requires weight to be on the seat when starting only. After running, you can get off and it will continue to run. Maybe it's not working right, but I don't think I could stand it cutting off everytime I come off the seat.
   / Does your tractor have a kill switch under seat? #37
I wired mine on a switch. If I am mowing I turn it on. For any other work I turn it off. My tractor is a HST transmission, so I don't worry about a seat safety anyway.
Butterfly Artwork (A55758)
Butterfly Artwork...
Pair of New 700/40-225 Alliance Tires with Rims (A55301)
Pair of New...
Case 1150G Crawler Tractor Dozer (A53421)
Case 1150G Crawler...
35176 (A55758)
35176 (A55758)
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2007 Yamaha Rhino 660 (A55301)
2007 Yamaha Rhino...
