doodlebug hay trailer
   / doodlebug hay trailer #21
Farmwithjunk said:
I've only been around one "tumblebug". It didn't have hydraulics to raise the bale. It required locking up the wheels and backing up to lift the bale. It had electric brakes, but they were wired "full on" or "full off". Brake was controlled via a toggle switch on a magnetic mounted controller that you could extend into a pick-up cab or place on a tractor fender. (Plugged into cig. lighter/power outlet) It wasn't DOT approved for hyway use so it was treated as a farm implement. I saw it used to move a 4'X4' round bale with a Volkswagon Jetta.
I am not familiar with this machine. This post makes the most sense. An easy check is to look at the trailer brake backing plate. If the brake wire is behind the axle, the brakes are for forward travel. If the wire is ahead of the axle, the brake will be actuated in reverse.
google them.. plenty of pics out there.
soundguy
2010 CATERPILLAR MINI EXCAVATOR 303C (A50854)
2010 CATERPILLAR...
2014 Ford Flex SUV (A50324)
2014 Ford Flex SUV...
2014 KENWORTH T800 SLEEPER CAB (A50854)
2014 KENWORTH T800...
2019 VOLVO VHD84F300 TRI-AXLE DUMP TRUCK (A51222)
2019 VOLVO...
2012 INTERNATIONAL LF687(INOPERABLE) (A50854)
2012 INTERNATIONAL...
2000 ADDCO DH1000 Message Board (A49461)
2000 ADDCO DH1000...
