DPF
   / DPF #91
Sure depends on the tractor, doesn't it? If your tractor has a clutch and geared xmission or is a powershift it doesn't work so good.
I am not sure I understand. If you are going to fast in one gear (at the correct RPM) then you shift gears, not decease engine RPM (drastically). I am not saying that everyone does it this way, I am just saying that is the way the tractors are designed to run.
  • Good Post
Reactions: RB5
   / DPF #92
I have a clutch and powershift. I have no issues doing loader work at 1500rpms. I used to get regens every so often until I read the manual and followed it.
   / DPF #93
Use the gears. This is why I have hi, medium, and low range with 4 selections in each.
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2014 Toro Workman HD 07369 Utility Cart (A54811)
2014 Toro Workman...
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
SKID STEER FORK ATTACHMENT (A53843)
SKID STEER FORK...
