Dr All terrain mower - works well for some small areas
   / Dr All terrain mower - works well for some small areas #11
Is that food plot wet? It does not look so wet? Would a riding mower not cut that foodplot on the highest setting? That looks like an awfull lot of work to mow a food plot!!
You are correct to much work, That is why I don't even try to cut all of it just some trails and some of the areas that grow sumac trees rapidly. This is the first year that I even tried to cut the trails. I have been just cutting it once a year with the bush hog but it is getting out of hand . So I am trying roundup
and the DR just to keep some areas in check until I can start cutting it more often.
The food plot is dry, unfortunately it is almost surrounded by a swamp.
I have one access road that is in really bad shape, so I can only get back there a very limited time in the year. The food plot was made from pine cutover with a bulldozer I think and it is really bad even with my tractor. No way my rider could work.
By the way it started raining right after I took those pictures and came down in buckets I had to wade through ankle deep water for a pretty good stretch just to get the DR out.
Really need to get the access road repaired but it is going to take some time and with everything else going on low priority at this point.
Does it have a pressurised oil system or a splash bath? The reason I ask is because I am looking for something to mow the sides of the ditches which are way to steep, my 2720 would tip over.
I think this old one is splash bath but I know they make a pressurized oil system version. I am hoping I really do not have to use it very long or very often until I can get my land a little more manageable. It will work you but it will cut down most anything
you can push over with it.
It sure beats a bushwacker blade on string trimmer !
   / Dr All terrain mower - works well for some small areas #14
I'm getting the feeling from this thread that it is a lot more work than I thought it would be. Maybe I will go back to my original thought to get a rotary cutter and let it hang over the edges of the ditch and call it good enough. It's only 500 feet long and the waterway in the field is 900 feet, both are about 30 feet wide.
   / Dr All terrain mower - works well for some small areas #15
Hey get the DR they almost run themselves. :D
Misery loves company. :)
I would go with your original thought too. That is way to much walking for me. I originally got this one just to cut the bottom and about 1 foot up on each side of my ditches. I cut the rest of the sides with my riding lawnmower. I only have about 500 feet of ditches so that works fine.
My rider was down for repairs last time so I had to use the DR for all of the sides of my ditches and the bottoms. Not fun at all , got the riding mower fixed this week so I am some happy
Good luck
   / Dr All terrain mower - works well for some small areas #17
We have the 42" grass mowing deck as well and because the DR does not have steering brakes it is a bear to turn around or keep straight on a hill side. We used our 10-15 hours during the month of April whipping my sister's place into shape before her auction. The son mowed a 10' path to the back side that was more like a mile long since was was almost horse shoe shaped. He could keep up with it wide open and in fourth gear but I can not walk that fast for very long. 4th is about the speed of an 800 Ford in 3rd gear at 1800 RPM.
Where ours really shines is mowing off property lines where I would not even take the 4x4 Polaris Magnum and trees that are not larger than a silver dollar at the ground.
   / Dr All terrain mower - works well for some small areas #18
Have had mine since about 1991 and it is a work horse. The one thing I do not like about my model is that it has thin bicycle type wheels, not the much wider ones that you see on the newer models. I guess that I might be able to find wider tires and wheels to fit it, but why? Am getting a tractor with a cutter attachment to do what I used to do with the DR.
Richard
   / Dr All terrain mower - works well for some small areas #19
I purchased a new DR last spring after looking for many years. One of my projects is about a 1/4 mile ditch bank. I managed to work the bottom and quite a bit up on the side hill. Two things happened...it got harder to keep on the hill and keep from over turning and I ran out of gas :) The DR is a beast...but lots of strength and effort in difficult side hills. I also cut a couple of 1/4 miles trails (Ranger width) through mostly small trees and brush clumps. While that was work, it was very effective and not nearly as much effort involved as when you get that monster on a side hill near the tipping point. I had planned a couple of additional passes on the steeper part of the hill...but the rain came and the ditch was wet the rest of the fall...will try again next year. What I did complete is great...may have to use a brush saw on the steepest part of the bank. The DR is a special purpose tool...works great for my applications.
   / Dr All terrain mower - works well for some small areas #20
When mowing slopes, go up and down, not sideways. My DR 12.5 HP is one of the smaller, older models, and I believe it does just as good of a job as the newer, heavier, higher HP units. Still, if I were to try wrestling with it on a side slope; it would be a battle.
Pair 2 - ST225/75R15 radial trailer (A55787)
Pair 2 -...
Two Pairs of 10ft Fork Extensions (A53421)
Two Pairs of 10ft...
UNUSED DIGGIT 72" HYD MULCHING HEAD (A54757)
UNUSED DIGGIT 72"...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
2018 Chevrolet Malibu Sedan (A53424)
2018 Chevrolet...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
