DR Power Grade Hydraulic Retrofit
   / DR Power Grade Hydraulic Retrofit #1
svlsmokey
N/E California
Branson 3520h
I have the older style DR Power Grade - 60" model. The actuator and remote system quit so I ordered the corded retrofit. That didn't work very well - it couldn't lift the grader back up with the concrete block in it. So I'm thinking of replacing the actuator with a small hydraulic cylinder. I've measured it all out and found a cylinder which will fit. Its rated for 1500 lbs max working pressure. My only question now deals with hydraulic psi coming out of the tractor. Will the pressure be too high and damage the cylinder? I have not found specs on the tractor yet (2015 Branson 3520h) - only that it runs 9 gal/min.
Open to your ideas. Thanks.
   / DR Power Grade Hydraulic Retrofit #2
I don't know the answer but interested in this project, put up some pictures when you are done! Thanks!
   / DR Power Grade Hydraulic Retrofit #3
Don't know specs on your tractor but every discussion I remember on here talked about 2-3000 psi on tractors.
   / DR Power Grade Hydraulic Retrofit #5
I'll be watching this thread. I had a customer give me his old one, but haven't thought through what will become of it.
The hydraulic cylinder arrived on Monday. Today I drilled out the holes in the actuator bracket and control arm to accommodate the 5/8 in bolts that will be needed for the new cylinder. I picked up a short section of threaded rod and a handful of nuts and washers. Seemed like the cheapest way to mount the cylinder.
The DR Grader is pretty lightweight and I noticed the actuator mount was starting to sag toward the inside. So I took it off to make sure it was clean between the side rail and the actuator mount. I bolted that back on and then added a brace from the inside of the actuator pin hole down to the rear spreading blade. That stiffened the actuator mount considerably. I used a piece of half inch metal electrical conduit for the brace. It matched the lightweight construction of the greater and I was able to easily crimp the ends flat. They do require an odd angle.
I will see if I can add some pictures.
   / DR Power Grade Hydraulic Retrofit #8
That's pretty slick. Let us know how it worked out.
   / DR Power Grade Hydraulic Retrofit #9
Have you played with this any further? I pulled the actuator off mine today and am in chin scratching mode....
The last two fittings I ordered from Supply Center are still on back order - might be in next month. I could get the fittings locally but they'd be a lot more expensive. We're frozen out there now so I'm not in a big hurry - but when things thaw out I hope to have it up and running.
New/Unused Grapple for CFG Mini Excavator (A54865)
New/Unused Grapple...
2001 Ford F-350 4x4 Flatbed Truck (A55852)
2001 Ford F-350...
2006 Ford F-350 4x4 12FT Flatbed Truck (A55788)
2006 Ford F-350...
UNUSED SDLGC80 Battery Powered Golf cart (A47477)
UNUSED SDLGC80...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A55302)
Adams Load Out...
2021 KENWORTH T880 5 AXLE DUMP TRUCK (A56129)
2021 KENWORTH T880...
