DR Power Grade Hydraulic Retrofit
   / DR Power Grade Hydraulic Retrofit #11
I was amazed at how well it groomed the gravel turn around. Mine is just the 4' version. For giggles I used an hunk of electrical strut for some adjustablity in place of the actuator and gave it a go. It could be worth bracketing up something for the three point I suppose for ease of maneuvering. Right now I just have a standard blade.
The fittings finally arrived today. Tomorrow I'll install them and post the final results!
The fittings arrived yesterday and I installed them this morning. It works! The rate of travel is MUCH faster than before - it almost jumps off the ground it moves so quickly. I suppose you could put some kind of flow control on it but I find its easy enough to push the lever down part way to slow down the flow of fluid to the cylinder. I'll try it on the road in the spring and let y'all know how it works.
   / DR Power Grade Hydraulic Retrofit #14
Tada! Thanks for the update.
Total cost was about $165. The electric actuator from DR (PN 38478) is $150 + about $20 S&H.
2012 Infiniti G25 Sedan (A53424)
2012 Infiniti G25...
1987 Landall 48ft 35 Ton Hydraulic Slide Axle T/A Drop Deck Trailer (A55852)
1987 Landall 48ft...
2018 Autocar ACX Xpeditor Garbage Truck (A55852)
2018 Autocar ACX...
2015 Chevrolet Silverado 3500HD 4x4 Crew Cab Service Truck (A53422)
2015 Chevrolet...
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
