Draft Links Won't Raise
   / Draft Links Won't Raise #11
You can plug a gauge into on of those ports, then operate the lever that energizes that port to take the reading. You are effectively "deadheading" the pump to see the PRV is set at. You won't have to find the test port since you have those remotes.
There are a least two pumps, on is usually just for the steering, and the other is for everything else.
Maybe you should inquire about the price of a service manual, they are usually less than $100.
Galvanized steel fence (A53424)
Galvanized steel...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
2007 Audi Q7 AWD SUV (A55758)
2007 Audi Q7 AWD...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2021 Bobcat S740 (A53314)
2021 Bobcat S740...
