DRAIN PIPE & CULVERT Leaf Screen
/ DRAIN PIPE & CULVERT Leaf Screen #2
Nice Idea.
I would also used it for keeping the critters out.
field mice etc..
nice job.
johnnylight said:
Nice Idea.
field mice etc..
*nice job.
* Thanks.
If I had it to do over agan i would not have drilled the holes in the cap as the screening is plenty of opening into the pipe.
The screening is held in place by two large hose clamps one on each end of the screening.
/ DRAIN PIPE & CULVERT Leaf Screen #4
I'm looking for ideas for cleaning out a 14" X 20' culvert. Sure don't want to dig it up. Keep thinking about some sort of roto-router driven off the tractor pto.
What is the culvert made out of?
Is it double wall smooth bore?
The state will clean out my smooth bore double wall plastic culvert if it gets plugged up.
/ DRAIN PIPE & CULVERT Leaf Screen #6
klm,
Any chance of blasting it out with a water stream? I've got one too that needs cleaning. Luckily, I have a fire hydrant within fire hose distance but a tank truck could supply water too. I think a 3/4" to 1" dia sked 40 pvc pipe with a 45 degree and hose fitting on the end would allow one to rotate the stream in a desired direction. I'd make four 5ft screw-together "rigid hoses", start at the far end and blast away. I have a non-adjustable fire nozzle that fits on a garden hose that shoots a fairly powerful stream at our unregulated 80psi source. These nozzles are available at many hardware stores like Orchard Supply or ACE.
/ DRAIN PIPE & CULVERT Leaf Screen #7
klm,
I had the same problem and posted here a couple years ago for solutions.
I had no water source near the plugged culvert, but I got the Fire department to come out and use their high pressure hose to un clog it. He got to it from both sides until he blew a hole through the clog. It was mostly sediment dirt, so once the hole was in it, the next rain opened it up again.
/ DRAIN PIPE & CULVERT Leaf Screen #8
It's actually an old steam pipe, smooth sided about 1/4" steel. Never thought about asking the state/county or fire dept. Both good ideas, will give it a try. There is no water source nearby.
UNUSED WOLVERINE RSB66-66" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
ASSORTED STIHL POLE SAW PARTS (A62613)
ASSORTED STIHL...
2015 Ford Explorer AWD SUV (A61574)
2015 Ford Explorer...
1997 TSE UTILITY WIRE REEL TENSIONER (A62613)
1997 TSE UTILITY...
UNUSED ATS POWER ATS-MIG-140 MIG WELDING MACHINE (A64281)
UNUSED ATS POWER...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
