Drive Over Deck 3000 series
   / Drive Over Deck 3000 series #11
orlo said:
Hi:
To the previous point about a RFM. I have a 72" 7 Iron MMM on my 3720 and switched to an 84" RFM (I still have the MMM and use it for Material collection/leaves). I run loaded R3's. My initial reason was to not have to deal with the pain of removing/installing the MMM every time I wanted to take it off to do some serious loader work. (It's a pain in the A#$ on the 3720 compared to the 62C on the 2305). You can do it, but it's a lot more work than on the smaller tractors.
After using the 84" RFM I can tell you 1 thing that's great about the RFM.... NO TIRE TRACKS!!!! I'm running 6" extensions (each side) on my 3720 with WIDE turfs and with the MMM when I mow I leave behind flattened grass (not dug up, just flattened). With the RFM it 'sucks up' the grass when it cuts it and I never drive over it again so it looks very nice. With the MMM, even though the Deck covers the tires width, Once the rear tires hit the grass again you'll flatten it out.
I have a Rear discharge and my only complaint is that I'd like a mulch kit since I can't direct the discharge like the side discharge MMM.
The RFM sure seems to be the easiest...
   / Drive Over Deck 3000 series #12
You know speaking of tire tracks, when I had the 4310, I would leave tire tracks for a day after I mowed, but with the heavier 3520 Cab, It does not leave a lot of tire tracks? I cannot figure this out at all?
Hand Truck (A52377)
Hand Truck (A52377)
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2022 DRAGON 130BBL VACUUM TRAILER (A53843)
2022 DRAGON 130BBL...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
2015 Ford F-450 Knapheide Service Truck (A51692)
2015 Ford F-450...
