Rear Blade driveway/land plane, homemade dimensions/drawing?
   / driveway/land plane, homemade dimensions/drawing? #1
mstone34
Brandon, MS
Kubota M4030
I am new here and wish to make 7' grader/land plane. I need diagram and dimensions, etc. Any help here?
Thanks for your time, Mal
   / driveway/land plane, homemade dimensions/drawing? #3
Do a little searching on TBN as there are some really great products that people have made. Impressive ones.
   / driveway/land plane, homemade dimensions/drawing? #4
Don't know how heavy your tractor is, info says 4000 -7300lbs. If you are on the lighter side, I would suggest that you only build a 6 footer. Either way, try to get it up in the 1000lb range and be sure that the sides are no less than 60" in length and 72" would get you a better finish grade. Is your main use going to be for roads or landscaping? Some guys prefer for the blades to be straight for landscaping purposes, I don't think that it really makes much difference myself.
I know that there seems to be roughly 3 different heights used for these graders. 12", 18" & 24" sides.
Good luck with your design & build, don't forget to post pictures, we all like pictures. ;)
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
2015 Kubota KX91-3S2 Mini Excavator (A55973)
2015 Kubota...
2011 SOUTHWEST  GOOSENECK (A55745)
2011 SOUTHWEST...
2018 WESTERN STAR 5700 TANDEM AXLE SLEEPER (A56138)
2018 WESTERN STAR...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
