We dodged a bullet. In the spring we were in a slight drought and normally we chop the 1st cutting due to weed's but it was so dry figured it needed to be baled in case it didn't rain, then it rained and rained and the sun came out and the 2nd cutting was great. Just finished the 3rd and have more hay than needed for the year to feed 250 dairy cow's. Now more than likely the 4th and if the weather hold's out 5th cutting will be chopped. The corn is almost 8ft with the ear's getting bigger by the day with this heat and humidity trouble with this is it takes forever to chop cause 2 dump truck's can't keep up. Well time to go loose about 15 pound's of sweatscott_vt said:Well in the northeast, anyone that could put up a descent amount of hay had to be a magicianThe longest span we had was two dry days and then the heavens opened up
The sheep farmer up the road from me usually has 5000 bales put up allready ! If he got a couple hundred he did good ! All we can hope for is a descent second cut !!! Fingers crossed !
