Dry gas additive.
   / Dry gas additive. #1
tcreeley
Elite Member
Hudson, Maine
2003 NH TC30
Local parts guy told me that I don't need to use NH 134 hydraulic oil in my NH TC 30. He had another hydraulic oil 20-25 dollars less than the 134. I asked what was different. He said the 134 had some additives for moisture. He said to just add a bottle of dry gas to the 9 gal. of oil when I changed it. Anyone else done this?
   / Dry gas additive. #2
It's suppose to help with water contamination in lower ethanal gasoline. I wouldn't just add to hydraulic fluid and run. I know some fuel additives with strong deposit cleaners are used as a flush in hydro systems but they are not intended to leave in.
The dry gas info I've read talks about guarding against "dry rot" for over use. Seems like it would cause more trouble with hoses than it would help with your problem.
   / Dry gas additive. #3
Not meeting Ford/NewHolland 134 spec is a bad idea. A $50 bucket sounds cheap compared to hydraulic issues. Some places meet that spec, that are slightly cheaper than name brand. Ive had good luck with Valvoline, and TSC.
   / Dry gas additive. #4
What a stupid recommendation by that "parts guy". "Dry Gas" is mostly methanol and it does not remove ANY moisture. It simply absorbs it into the alcohol which is then burned in an engine.
Hydraulic fluid is not burned of course so the resulting alcohol/oil mixture will be there indefinitely.
I'd run fast away from that "parts guy":thumbsup:
   / Dry gas additive.
It was a New Holland dealership that told me this.
   / Dry gas additive. #6
I certainly wouldn't want to contradict a tractor dealer, but there's no way I'd put that stuff in a tractor I owned.
   / Dry gas additive. #7
Other brands will work. They all clearly state the specs. Take Kubota UDT for example. I know its rebranded Valvoline. I don't think you can wrong at Napa. That's where Id go.
   / Dry gas additive. #8
Methanol in " dry gas" will attack polymer seals and other parts . I would not use it in a hydraulic system. Some " dry gas" formulations of a similar nature are ethanol, which is not quite as bad, but as pointed out above, the alcohol simply combines with the water, but it's all still there. The main function of "dry gas" formulations is to combine with the water in the bottom of your fuel tank, and prevent it from freezing in cold weather, when it might clog up your fuel pickup or fuel pump. Adding alcohol to gasoline does not pull the water in the bottom of your tank up into solution with the gasoline. Small amounts of alcohol in gasoline does slightly increase the amount of water that the gasoline can hold, but we're talking parts per million ,and not the large quantities people expect.
   / Dry gas additive. #9
That's funny,stick with the 134 spec oil.
   / Dry gas additive. #10
I'd sooner go with just of the shelf hyd oil and not be concerned. Ive used off brands for the last 30 years all with no ill results..
Or just spend the extra and use waht they recomend...
TEST YOUR BID BUTTON! (A52705)
TEST YOUR BID...
KUBOTA M5660 SU TRACTOR (A52706)
KUBOTA M5660 SU...
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED TRAILER (A53843)
2010 UTILITY...
2022 CATERPILLAR 980 WHEEL LOADER (A52705)
2022 CATERPILLAR...
