dual grade rotary laser
   / dual grade rotary laser #11
So a different receiver is required for two channels so to speak?
   / dual grade rotary laser #12
No. I have only one receiver on my blade. The laser transmitter sends only one beam out, which is captured by the receiver. And that beam can be tilted either, or both, north/south, and east/west
   / dual grade rotary laser #13
Nope, the laser is the same. You can just adjust it from level N/S AND E/W. Single slope will only adjust N/S. Obviously you can rotate it before setting slope, but you get the idea.
Dual slope models are much more likely to be stable to a specific value. Like type in a 1% grade & it sets it in the X or Y plane. Single slope units seem to have no screen & adjust a tiny, probably fixed amount every time you hit the up or down arrow... if it's getting signal from the IR remote, which is drowned out by the sun at even short distances. Or walk back to the laser & hit a button. Either way you have to measure off a fixed distance & do the math then change the slope, then re-measure. Then repeat that loop a ton.
Service Truck (A59230)
2017 Chevrolet Impala Sedan (A56859)
2017 Chevrolet...
2022 CATERPILLAR 299D3 SKID STEER (A52709)
2022 CATERPILLAR...
2009 Sterling L Line Rollback Tandem Truck w/ Drop Axle (A59213)
2009 Sterling L...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2014 John Deere 855DXUV Gator (A57149)
2014 John Deere...
